Cisco 831 router EIGRP
rgrant22
We were unable to do EIGRP on the Cisco 831 router. Do this router support EIRGP? If so, which code? I am using
c831-k9o3sy6-mz.124-1c.bin.
stomasko
Level 4
Level 4
Feature navigator doesn't show your particular version however 12.4(3c) does show eigrp support for the 831.
What happened when you tried to issue the command?
Hope this helps
Steve
Harold Ritter
This version that you are using should allow you to run eigrp as follow:
W228.08.07-800-2#sh ver
Cisco IOS Software, C831 Software (C831-K9O3SY6-M), Version 12.4(1c), RELEASE SOFTWARE (fc1)
W228.08.07-800-2#config t
Enter configuration commands, one per line. End with CNTL/Z.
W228.08.07-800-2(config)#router eigrp 1
W228.08.07-800-2(config-router)#end
W228.08.07-800-2#s
*Jul 13 06:55:29.613: %SYS-5-CONFIG_I: Configured from console by consoleh ip prot
Routing Protocol is "eigrp 1"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Redistributing: eigrp 1
EIGRP NSF-aware route hold timer is 240s
Automatic network summarization is in effect
Maximum path: 4
Routing for Networks:
Routing Information Sources:
Gateway Distance Last Update
Distance: internal 90 external 170
W228.08.07-800-2#
Hope this helps,
