Cisco 831 Router
Jason Aarons
Level 6
Level 6
I installed the new 831 router and was able to connect via the tunnel from my office. Unfortunately once I disconnected my pc from Fa4 from the router the tunnel timed out and I am no longer able to connect to the router from my main office. I did not configure a loopback address, and was wondering, is there any other way to connect to this device without having something on the 4 ethernet ports. I know on the DSL sites, I can connect to the serial side of the 837 routers.
Is there a keepalive command to always have the tunnel up in IPSec?
Harold Ritter
You should consider the Generic Routing Encapsulation (GRE) Tunnel Keepalive feature. For more information, please refer to the following URL:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087cec.html
Hope this helps,
