Multiple gateways for VLANS
stikekar
I have multiple VLANS running on a 6509 layer 3 switch. Currently all the VLANS use the default ip route to a fiewall to access internet. I want to change this. I want to assign some VLANS to a different gateway firewall to access internet. How can I achieve this. Any help will be greatly appreciated.
t.hadarson
You can use policy routing.
Example:
Define access-list with ip address of network who should use a different gateway.
access-list 10 permit x.x.x.x 0.0.0.255
Route-map [name of map] permit
match ip address 10
set ip default next-hop [ip of gw]
bind the route map to a vlan interface
interface vlan 100
ip policy route-map [route-map name]
Regards Tony
Thanks Tony. I will pursue this path.
thisisshanky
Level 11
Level 11
You can do policy routing for those vlans and set the next hop to a different gateway.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
