Cisco 837 as ADSL2+ router
damiankwest
Hey guys, I hope someone can answer a few questions I have and see about fixing a configuration I'm having issues with!
I have a situation where I have ADSL2+ with a couple of additional IP Addresses, unfortunately my current router doesn't support NAT Translation properly, nor does it support additional IP's on the same interface .. so my solution was to bridge the current router (Netgear DGN2000) and push it into a Cisco 837 which I have laying around for no apparent reason.
My idea was to bring up the Ethernet0 interface as a LAN interface and the Ethernet2 as a WAN interface and route traffic between them, however I'm having issues getting the WAN to authenticate properly - I have never does PPPoE authentication on a Cisco before, let alone when I'm not using the ATM0/Dialer0 interfaces to do so!
My configuration is attached as it is, I wasn't sure if I needed to configure my real-world IP Address in the Ethernet2 interface, or the Dialer0 interface would take care of that for me? I used the configuration tips in (http://www.cisco.com/en/US/docs/routers/access/800/819/software/configuration/Guide/9ppp_e_nat.html) to configure what I have now but wasn't sure if it would work on a different device.
The last things is, I read somewhere that the Ethernet interfaces on the 837 were 10Mbit only - would this mean that if I push my ADSL2+ link through it, I wouldn't be able to get faster than that? Or would it disregard this as I'm physically connecting through a FastEthernet port?
Thanks for any assistance you can give me on this.
Hi Damian,
Your configuration has following problems:
  1. The routing is deactivated (I wonder how did it happen) so the router is not a router at all. Correct this by adding the ip routing and ip cef to your global configuration.
  2. The VPDN is activated unnecessarily. Remove the VPDN configuration altogether by entering the no vpdn-group TPG and no vpdn enable in your global configuration.
  3. Remove the NAT configuration from the Ethernet2 interface - as this interface is not IP-enabled, configuring IP NAT is useless. Enter the no ip nat outside in the Ethernet2 configuration.
  4. On the Ethernet2 interface, try removing the pppoe enable command. This command activates the PPPoE server functionality which is useless, as you are a client. The only necessary command with respect to PPPoE is the client configuration you already have present thanks to the pppoe-client dial-pool-number 1 command - that command should stay on Ethernet2.
  5. On Dialer1 interface, add the ip tcp adjust-mss 1452 command to make sure TCP sessions do not create oversized segments requiring fragmentation. Also add the ip nat outside command, as it is the Dialer1 interface that is the IP-enabled interface facing the outside world.
  6. On Dialer1 interface, the dialer-group and ppp authentication commands are unnecessary and should not be present. The first command defines a list of "interesting traffic" that can cause a dialer to dial a number but this is relevant only for dialed technologies such as analog modems or ISDN, not in PPPoE. The second command actually causes that you require your ISP to authenticate to you in certain cases, and this is wrong. Therefore, issue the following commands in Dialer1 configuration:
    1. no dialer-group 1
    2. no ppp authentication chap pap callin
  7. Remove the ip route 10.0.0.0 255.0.0.0 Dialer1 static route, and replace it with ip route 0.0.0.0 0.0.0.0 Dialer1 - I assume that you want all internet connectivity to go through the Dialer interface.
  8. Remove the ip nat inside source list Internal interface Ethernet2 overload and replace it with ip nat inside source list Internal interface Dialer1 overload - it is the Dialer1's IP address you are hiding your internal network behind.
Try making these changes and test your connectivity again. If it still fails please post your then-current config.
Best regards,
Peter
9 Replies 9
damiankwest
Alright, so silly me posted a WORKING configuration thinking that it wasn't working, it's been a long day.
So I have the PPPoE interface up, however I can't get connection out to the internet at all, I'm wondering what I'm missing in this regard?
If I do a ping, then configure to go from dialer1 to 8.8.8.8 it times out without success.
If I do a ping to 10.0.0.15 (another machine on my network) it works fine.
I'm new to the routing side of things, not sure exactly what I need to do in order to make things route out to the internet after the internet connection is up and running - or even if I have to route to interface Dialer1 (or) Ethernet2
Any help with this would be greatly appreciated
Hi Damian,
Best regards,
Peter
You are a legend Peter! I understood all of what you said too, amazing. A couple of notes:
  1. The guide I went through said to put in vpdn - but you were right, once I deleted it, the connection dropped and then came straight back up.
  2. After doing the no pppoe enable, I had to re-do the pppoe-client command as it had removed itself.
  3. Thanks with the routing tips, this is what I was missing, I wasn't sure about the Dialer1 vs. Ethernet2 parts, or the correct ip ranges to route - it all makes a lot more sense now!
I just did a full reboot of everything to ensure it comes back up and it has! Success!
Unfortunately I've tested the internet connection and I am only getting 10mbit which is a bit sucky as my ADSL2+ modem actually connects at 20mbit! I thought this might be the case as the eth0/eth2 interfaces are only 10mbit, but I was hoping it would bypass this as it's physically using the fe1/fe4 ports.
Anyway, there's one more slight error that's coming up constantly - and was before the changes were made as well:
- Vi1 PPP: Outbound cdp packet dropped
I read somewhere that this had to do with the MTU packet size, which I think is what you correct with the ip tcp adjust-mss 1452 command?
Thanks for your help with this, I really appreciate it!
Hi Damian,
It's so good to know you got it running!
I am surprised at the guide. The VPDN does not seem to be relevant at all to this configuration. Perhaps it was relevant in some ancient IOS versions but with your IOS version and newer, it most certainly is not required - just as you've seen for yourself. A pure and clean PPPoE client is what you need - and what you get by the single pppoe-client command.
Okay. Then it's IOS-enforced behavior.
Hmmm. This may be difficult to solve - this depends whether the connection between the 100Mbps 4-port switch in the router and the CPU itself is running on 10 or 100 Mbps. This router is quite old; it may have lots of bottlenecks.
Are you able to download a newer IOS for your router? The latest IOS version for 837 router is c837-k9o3sy6-mz.124-15.T14.bin - this version should theoretically allow us to access individual ports of the FastEthernet switch in configuration, possibly putting them into different VLANs. I would like to see if we could get an improvement if we did the configuration on interface Vlan instead of physical interfaces in your configuration (though, to be honest, I strongly doubt there will be any difference - the bottleneck is not caused by the name of the interface in the configuration but rather by physical construction of the router).
This is absolutely normal. The PPP protocol negotiates with the other party which protocols are allowed over the PPP link. Check out the show interface output for interfaces Dialer1 and Vi1 - look for something like:
  Encapsulation PPP, LCP Open
  Listen: CDPCP
  Open: IPCP, loopback not set
This output tells you that the IP protocol has been negotiated on the link by both parties (IPCP stands for IP Control Protocol which is the negotiation protocol for enabling the use of IP over a PPP link). However, the CDP Control Protocol, or CDPCP, is only in the Listen state, saying that your router has suggested that CDP is also carried over the PPP link but the other endpoint has not agreed to that. This means that CDP is not allowed to be carried over this link, and that is the reason why you see CDP packets being dropped - because CDP has not been negotiated by both endpoints of this PPP session. This is quite common for CDP: PPPoE access concentrators at your ISP are configured not to send CDP packets to individual customers, or they are from different manufacturer than Cisco and do not speak CDP at all.
Not in this case, I believe - CDP packets are not that big to exceed the MTU of 1492 bytes. They are dropped because CDP has not been negotiated for use of the link - see the explanation above.
Well, this command applies only to TCP sessions passing through the Dialer1 interface, and it causes both endpoints of a TCP session to send TCP segments of no more than 1452 bytes in the segment body. It does not apply to other types of traffic - UDP, ICMP, IP, all these are unaffected by this command.
Best regards,
Peter
Thanks again for that Peter! Explanations are fantastic for future reference. I have tried to update the firmware in the device, however when I do it comes up 'not enough space on device'. The firmware is about 12.6MB and it seems the flash size is only 12.3MB!
I took a quick look at the other filesystems on the device and the flash is the biggest one. I guess it just wasn't meant to be in the case, lol. But not to worry, I really wanted to see if I could make this work but I might just see if I can find another router I can play with. I definitely learnt a lot trying to give this one a go, as well as your insightful notes on each part I was doing wrong.
If you have any suggestions on how I can update the firmware, fantastic, if not don't worry too much, it'll be more just for testing purposes anyway
Thanks again Peter!
Hi Damian,
Perhaps you could try the c837-k9o3y6-mz.124-15.T14.bin or c837-k9o3sy6-mz.124-25d.bin images and see if they fit into your FLASH. Both should be feature-rich enough for your needs.
Best regards,
Peter
Hey Peter,
I hope you don't mind that I piggy-back on this post. I ended up giving the 837 the flick just due to the speed - From what I read it was the hardware holding the speed back, so I didn't bother updating anything more.
I have now got myself a 857W which I am 99% through configuring, however I'm having a couple of issues with routing (again, not my strong suite). ADSL2+ connects, LAN connects, from the Cisco I can ping both the internal network and the external network, from outside of the network my NAT rules work, however from inside the network I can't get to the internet.
I have double checked the configuration with a few other configurations and I can't seem to find any reason why it would be doing what it's doing, I was hoping you (or someone else) would be able to give me what I'm sure is a simple command I'm missing!
I have tried with / without an access list on the Vlan1 but I can't get my head around it :\
Below is my Cisco 857W configuration, thanks
version 12.4
no service pad
hostname NIC-GW01
boot-start-marker
boot-end-marker
enable secret 5 ..
no aaa new-model
resource policy
ip cef
username admin privilege 15 secret 5 ..
interface ATM0
description Interface to the external network
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip mtu 1492
no snmp trap link-status
pvc 8/35
  oam-pvc 0
interface FastEthernet0
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
description Connection to Internal network
ip address 10.0.0.1 255.0.0.0
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname damiankwest
ppp chap password 0 ..
ppp pap sent-username damiankwest password 0 ..
interface Dialer1
no ip address
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source static tcp 10.0.0.16 25 x.x.x.x 25 extendable
ip nat inside source static tcp 10.0.0.20 80 x.x.x.x 80 extendable
ip nat inside source static tcp 10.0.0.16 443 x.x.x.x 443 extendable
ip nat inside source static tcp 10.0.0.17 3389 x.x.x.x 3389 extendable
ip nat inside source static tcp 10.0.0.16 3389 x.x.x.x 3390 extendable
ip access-list extended Internal
permit ip 10.0.0.0 0.255.255.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login local
scheduler max-task-time 5000
end
damiankwest
Wait, I figured it out. lol
I was using Dialer0 as the dialer, but referencing Dialer1 in my NAT rules
Thanks for the help!
Damian,
Congratulations - you got it working perfectly!
Best regards,
Peter
