12-27-2013 05:48 AM - edited 03-04-2019 09:57 PM
Hi all,
Im going a bit insane. I cant seem to get my internet working when im going from my rogers cable modem to my 2811 router then to my switch. I have tried so many different configs and nothing has worked. Im sure its just something really simple. Here are some configs from my router
version 12.4
service config
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$u2yV$MIbSd1JXvXTQDfPTatF.f0
no aaa new-model
resource policy
memory-size iomem 15
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.3
ip dhcp pool DATA
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 4.2.2.2 2.2.2.5
domain-name cody
voice-card 0
no dspfarm
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex full
speed 100
interface Service-Engine0/0
ip address dhcp
interface FastEthernet0/1
ip nat inside
duplex auto
speed 100
ip default-gateway 192.168.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip nat source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
password cisco login
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
I gave my interface 0/0 dhcp which is from my cable modem should I just be using the single public Ip the gave me 99.248.230.X
Please help Trying to move on to my cisco voice but this stupid little problem is holding me back thanks
Solved! Go to Solution.
12-27-2013 11:09 AM
So did the ISP give you the static 99.248.230.x IP or is that what you are seeing the router get from DHCP?
12-27-2013 11:09 AM
12-27-2013 11:34 AM
In addition to what Collin is asking, when you had it configured for dhcp, do you get an address at all? If so, can you ping anything past the provider like 4.2.2.1?
HTH,
John
*** Please rate all useful posts ***
12-27-2013 12:18 PM
Hey sorry I finally got it working and decided it was time to leave my room. The problem I was having was I forgot to put inside nat as followed:
Ip nat inside source list 1 interface 0/0 overload
Or something like that I'm on my phone so hard to type. I appreciate tha responses though thanks for your help
