Cisco 837 NAT problem
husseinmuneer
Dear Sir,
I have cisco 837 ADSL router so sometimes suddenly no internet access (internet disconnect).
I entered to the router by console then ping to ISP's DNS ( public IP address) it's ok then ping to my laptop it's ok too but from my laptop to this public IP address no reply!!
I made continuous ping from my laptop to ISP's DNS ( public IP address) there was request timed out after I delete the NAT command and return it the ping changed from request timed out to reply !!  so what is the problem? it's IOS problem, Hardware problem or RAM or what?
This is the configuration and what I did to solve the problem:
sh run
Building configuration...
Current configuration : 2006 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
memory-size iomem 5
enable secret 5 $1$Idzo$jLBd.1OKb.acRpU8dhsqr/
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
--More--                           aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
resource policy
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp pool cisco
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.254
   dns-server 65.162.184.33 65.162.184.34
ip cef
no ip ips deny-action ips-interface
username test privilege 15 secret 5 $1$zISo$n1r4KtszsxxGM8ni/48bV/
--More--                           !
interface Ethernet0
ip address 192.168.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
hold-queue 100 out
interface Ethernet2
no ip address
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
--More--                           !
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
--More--                            dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname muneer1
ppp chap password 0 123456
ppp pap sent-username muneer1 password 0 123456
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
--More--                           line vty 0 4
password 123456
scheduler max-task-time 5000
end
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#no ip nat inside source list 1 interface Dialer0 overload
Dynamic mapping in use, do you want to delete all entries? [no]: y
Router(config)#ip nat inside source list 1 interface Dialer0 overload
Router(config)#^Z
Router#
Regards.
Muneer
muneer@yemen.net.ye
When Internet stops working from your computer can you test if you can still PING the internet from the router itself?
i.e
ping 4.2.2.2
If the router is not losing Internet and the problem is only with the internal LAN, then check if you can PING the default gateway of the router from the laptop.
From the computer: ping x.x.x.x -->  x.x.x.x is the IP from ''sh ip route''
Additionally, how many computers/hosts do you have behind the router getting out to the Internet?
I'm just wondering if there are too many translations/connections going through the router at any given time (NAT table getting full).
Federico.
Dear Federico,
Thank you for your help.
When the internet hang in the laptop the ping still working from the router to outside because I was pinging to the ISP's DNS which has public IP address.
In the same time I can entered to the router by telnet from the laptop which mean I can ping from the laptop to the router.
About ping from the laptop to the gateway of the router I didn't try it so I will try to do it when it hang another time.
The computers behind the router just my laptop but do you think the viruses can make this problem?
