Cisco 837 router does not connect to ADSL.
marianodaniel
Hello! Here again, being one of those annoying people coming with legacy devices that don’t work.
This time, I managed to access my Cisco 837 using a Windows 98 VM. Only problem is, when trying to enter my ADSL username and password (and VPI/VCI) but I get the following error:
Workarounds/Tests/Info:
  • The DSL cable is connected and works ok with my other router.
  • The only information I do not know for sure, is the VPI/VCI, I got it from a forum for my ISP.
  • I have reset the router to factory defaults.
Is there a way to read more detailed logs? Might be the ADSL port broken? I’m at loss 🤷🏻‍
Any help or tips are much appreciated!
32 Replies 32
congratulations on being a dad ! That is of course a whole lot more important than configuring an old 837.
Either way, I don't know which configs you have tried already, but the most important thing is to to bind the ATM interface to the dialer. I have put together a very basic configuration (important parts marked in bold).
Who is the ISP again ?
cisco837#sh run
Building configuration...
Current configuration : 3486 bytes
version 12.4
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname cisco837
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 XXXXXXXXXX.
no aaa new-model
resource policy
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 8.8.8.8
lease 0 2
partition flash 2 11 1
username CRWS_Sangeetha privilege 15 password 7 XXXXXXX
username cisco837 password 7 XXXXXXX
username CRWS_Giri privilege 15 password 7 XXXXXXX
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
--> encapsulation aal5mux ppp dialer
--> dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname 9720461000
ppp chap password 7 xxxxxxxx
ppp pap sent-username 9720461000 password 7 xxxxxxx
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
end
EDIT: you might need to add these lines to the dialer interface:
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
@Georg Pauwen , I've been trying like crazy to enable SSH or FTP on the router so I can inject this config on a file, but it's impossible. I create all the keypairs and all, but SSH will not enable.
I've tried to push each command into the CLI, but I'm having trouble with some of them.
Is there a way to edit the file directly? I know 800 series routers are way too old for this.
After a few months attempting to get it to dial the ADSL, I'm thinking about giving up the task xD
how old is the router ? It might very well be that the DSLAM of your ISP does not support the specific modem (firmware) of your router.
Can you post the output of:
sh ver
