Cisco 837 Routing issue?
jbryan189
I have a 837 that I'm getting setup for a charitable cause. I copied most of another operation setup but am having issues with the routing, I think.
THe ATM appears to be correct using the "ping atm interface 0 0 35 end-loopback" command.
I have pasted the run-config below:
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
logging buffered 51200 debugging
no logging console
enable secret 5 $1$si4C$szqLUXsYOryuvNbl3Qnw2/
enable password 7 13151810595D53
no aaa new-model
ip subnet-zero
no ip source-route
no ip routing
ip tcp synwait-time 10
ip dhcp excluded-address 10.0.0.1 10.10.9.255
ip dhcp excluded-address 10.10.11.0 10.255.255.254
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
network 10.0.0.0 255.0.0.0
default-router 10.10.10.1
dns-server 8.8.8.8 8.8.4.4
no ip bootp server
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 10.10.10.1 255.0.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache
ip tcp adjust-mss 1412
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname XXXX@XXXX.net
ppp chap password 7 1307050B0A02577B7C76
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0
ip http server
ip http secure-server
logging trap debugging
dialer-list 1 protocol ip permit
no cdp run
line con 0
no modem enable
line aux 0
line vty 0 4
password 7 12090A15435D55
login
scheduler max-task-time 5000
scheduler interval 500
end
As always thanks for the forums help!!! John
John Blakley
It looks like you're missing the "ip nat outside" command on the dialer interface.
Try this:
access-list 10 permit 10.0.0.0 0.255.255.255
ip nat inside source list 10 interface dial0 overload
int d0
ip nat outside
And you may need to change your default route to point to dialer0 instead of atm0...
There's some other documentation that I'm finding from Cisco that states to put the nat statement on the ATM interface though:
http://www.cisco.com/en/US/docs/routers/access/500/520/software/configuration/guide/520scg_ppp_atm_nat.html
HTH,
John
HTH, John *** Please rate all useful posts ***
Routing is also disabled so you should enable it with the global config command: ip routing.
Regards.
Alain
First, Thanks for the help!! New guy blues...
Looks right as best my untrained eyes can tell.
I am currently here, with not much success:
Current configuration : 2215 bytes
version 12.3
no service pad
hostname Router
no logging console
no aaa new-model
ip subnet-zero
no ip source-route
ip name-server 64.250.192.64
ip name-server 64.250.192.65
no ip bootp server
ip audit notify log
interface Ethernet0
no ip redirects
no ip unreachables
no ip proxy-arp
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/35
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname
xxxx
ip classless
ip http server
no cdp run
line con 0
no modem enable
line aux 0
line vty 0 4
login
