Cisco 857: Always lost the first ping !
osgpcqosg
Hi a was looking about a problem (https://supportforums.cisco.com/thread/2058182) and I found a strange bug with this modem and this version of IOS:
  857 Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
I always use the "ping -c1 -M do -s 1472 xxx.xxx.xxx.xxx" from a linux box connected to the cisco adsl 857, so with this bug and the use of -c1 option, you get always bad result.
Cisco just solve this issue in the:
  857 Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T15, RELEASE SOFTWARE (fc3)
If you have the same problem, maybe this could help you...
Best Regards
osgpcqosg
If you don't want to do the upgrade to the last IOS you could use the "no ip cef" command.
This command slove the problem.
