Cisco 857 MER configuration
ignaciobajo
I have router ADSL connecition with MAC Encapsulation Rputing (MER) protocol
I need change the original ISP router to cisco 857, in cisco, MER is equivalent RFC 1483 routing.
The Configuration-Remote Site Profiles is
- No USER or PASS requiered
- MAC Encapsulation Routing (MER)
- VPI: 0, VCI: 44
- Unspecified Bit Rate
- Enable IP Routing
- Constant Cell Rate: 0
- Encapsulation mode: LLC/SNAP-bridging
I configure a cisco 857 with the confiuration bellow, and the ISP give a IP address, but if i try a ping to external IP, don´t respond
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address dhcp
ip nat outside
ip virtual-reassembly
atm route-bridged ip
pvc 0/44
  encapsulation aal5snap
interface Vlan1
ip address 192.168.10.124 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip http server
no ip http secure-server
ip nat inside source list 1 interface ATM0.1 overload
access-list 1 permit 192.168.10.0 0.0.0.255
The resul of show ip interface atm0.1
ATM0.1 is up, line protocol is up
  Internet address is 95.62.239.88/24
  Broadcast address is 255.255.255.255
  Address determined by DHCP
  MTU is 4470 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is disabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF Feature Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
Best regards
I Had this problem too,
Configuration is OK, please change Default Gateway to Next-hop to your provider default Gateway or create a Dialer configuration!
