cisco 857 router - problems config interface fastethernet ip address.
p.cavaleiro
I am trying to configur a cisco 857 router and experienced problems with the config of the interface fastethernet ip address.
Can someone please help-me?
"R2(config)#int fastether0
R2(config-if)#ip address 192.168.1.251 255.255.255.0
% IP addresses may not be configured on L2 links.
R2(config-if)#"
Thanks in advance
Pedro
2 Accepted Solutions
cadet alain
I suppose you connect your internal machine on fa0 then do this:
int vlan 1
ip add 192.168.1.251 255.255.255.0
Alain
Because this is  a Layer 2 interface(switchport) not a Layer 3 interface and you can't assign an IP to a L2 interface.
Alain
5 Replies 5
cadet alain
int vlan 1
Alain
I did nothing on this..."connect your internal machine on fa0"
I allready done
"int vlan 1
ip add 192.168.1.251 255.255.255.0" and OK.
but my question is why it do not let me configur fa0.
pedro
Alain
Ok, thanks
pedro
Good day,
I am trying to connect my c3650 layer 3 switch to the internet via cisco 891-k9 router, the problem is my vlans (2-12) on my layer 3 switch cannot pass through the internet. i have configured  one the LAN ports of my router to trunk mode and my layer 3 switch but still not working. but if i connect to the port on my layer 3 switch with no vlan assigned i have no problem connecting to the internet.
Pls. help.
Rolf
