Cisco 871 IPSEC bandwidth
desmond.liew
Dear all,
I have setup a Cisco 871 router configured with VPN and Internet service. My line is a 1M line and I am wondering if there is a minimum or maximum bandwidth used for VPN.
When there is no traffic, how much bandwidth does a keep-alive traffic take if it is enabled?
Also, in what order does Cisco matches traffic first?
I have attached a my sample configuration.
version 12.4
no service pad
hostname TEST
boot-start-marker
boot-end-marker
logging buffered 16384
no aaa new-model
ip cef
crypto pki trustpoint TP-self-signed-1579893558
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1579893558
revocation-check none
rsakeypair TP-self-signed-1579893558
crypto pki certificate chain TP-self-signed-1579893558
certificate self-signed 01
3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
C1AB46A9 1B23B635 6781BBDC F24B6518 DAC5EEFB 521CF839 5E553763 C850049B 7F4470
quit
username admin privilege 15 secret 5 $1$J5X7$Lza4y093b9CI2eCPj3zN9.
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key jmdgpmwajjtd address <REMOTE_IP_ADDRESS>
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to<REMOTE_IP_ADDRESS>
set peer <REMOTE_IP_ADDRESS>
set transform-set ESP-3DES-SHA
match address 100
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
bandwidth 1024
ip address <ROUTER_IP_ADDRESS> 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 172.30.205.1 255.255.255.0
ip access-group 130 in
ip nat inside
ip route 0.0.0.0 0.0.0.0 <GATEWAY_IP_ADDRESS>
ip route 133.0.0.0 255.0.0.0 172.30.162.254
ip route 172.30.159.0 255.255.255.0 172.30.162.254
ip route 172.30.160.0 255.255.255.0 172.30.162.254
ip route 172.30.161.0 255.255.255.0 172.30.162.254
ip route 172.30.162.0 255.255.255.0 172.30.162.254
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet4 overload
access-list 100 remark SDM_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 172.30.205.0 0.0.0.255 133.0.0.0 0.255.255.255
access-list 100 permit ip 172.30.205.0 0.0.0.255 172.30.159.0 0.0.0.255
access-list 100 permit ip 172.30.205.0 0.0.0.255 172.30.160.0 0.0.0.255
access-list 100 permit ip 172.30.205.0 0.0.0.255 172.30.161.0 0.0.0.255
access-list 100 permit ip 172.30.205.0 0.0.0.255 172.30.162.0 0.0.0.255
access-list 101 deny ip 172.30.205.0 0.0.0.255 133.0.0.0 0.255.255.255
access-list 101 deny ip 172.30.205.0 0.0.0.255 172.30.159.0 0.0.0.255
access-list 101 deny ip 172.30.205.0 0.0.0.255 172.30.160.0 0.0.0.255
access-list 101 deny ip 172.30.205.0 0.0.0.255 172.30.161.0 0.0.0.255
access-list 101 deny ip 172.30.205.0 0.0.0.255 172.30.162.0 0.0.0.255
access-list 101 permit ip 172.30.205.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 101
control-plane
line con 0
login local
no modem enable
line aux 0
login local
line vty 0 4
login local
transport input ssh
scheduler max-task-time 5000
end
irisrios
Level 6
Level 6
With default settings router do not limit the bandwidth allocated for a VPN client. VPN client connection can get as much bandwidth as possible. You have to impose special QOS policies if you want to limit bandwidth.
