CISCO 871W cannot ping external router interface
jprophet64
Good morning everyone,
I hope someone here could assist me with the situation I am facing, I am a network administrator who has been assigned the task of adding a secondary router to a redundant backup third party provided internet circuit. This router will serve two-fold firstly it will serve out dhcp addresses through a dhcp pool and secondly it will accomodate 2 Unifi AP access points. I'll show my config below but the end result is I cannot ping the outside router interface that the ISP has provided which ultimately should allow me to get on the internet.  My config is below:
CLTCHIEF2#show run
Building configuration...
Current configuration : 1934 bytes
! Last configuration change at 17:52:47 UTC Sun Mar 3 2002
version 15.1
no service pad
service password-encryption
hostname CLTCHIEF2
boot-start-marker
boot-end-marker
enable secret 5 $1$fMm.$fVzzs3q6pnSM6avr03Nho1
enable password 7 12211D0E081115
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 172.16.102.1 172.16.102.99
ip dhcp excluded-address 172.16.102.151 172.16.102.254
ip dhcp pool CLT2WIRELESS
   network 172.16.102.0 255.255.255.0
   default-router 172.16.102.1
   domain-name INTERNAL.COM
   lease 7
ip cef
no ip domain lookup
bridge irb
interface FastEthernet0
interface FastEthernet1
 shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 description WAN INTERFACE
 ip address 50.58.80.82 255.255.255.252
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface Dot11Radio0
 no ip address
 shutdown
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
 54.0
 station-role root
interface Vlan1
 description VLAN WIRED AND WIRELESS
 no ip address
 no ip redirects
 bridge-group 1
interface BVI1
 description VIRTUAL BONDED INTERFACE
 ip address 172.16.102.2 255.255.255.0
 no ip redirects
 no ip unreachables
 ip nat inside
 ip virtual-reassembly max-reassemblies 1024
 ip tcp adjust-mss 1360
 load-interval 30
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 150 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 172.16.102.1
ip route 0.0.0.0 0.0.0.0 50.58.80.81
access-list 150 remark NAT TRANSLATIONS
access-list 150 permit ip 172.16.102.0 0.0.0.255 any
snmp-server community public RO
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 password 7 07173955541300
 login
 transport input all
end
Does this config look right?
Thank-you.
53 Replies 53
Ok things are starting to look up now I now have the dhcp pool serving an address now to my laptop and I can now ping the .81 from laptop but not .82 which has been tied to interface fa4, cant quite figure thatt one out here is the latest config folks.
Current configuration : 1696 bytes
! Last configuration change at 01:01:35 UTC Fri Mar 1 2002
version 15.1
no service pad
hostname CLTLVLTHREE
boot-start-marker
boot-end-marker
enable secret 5 $1$b126$CBurGrg/NkVtK63I7p4fg.
enable password 7 05331E163B5657
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool CLTLVL3
   domain-name CLTINTERNAL.COM
   lease 7
ip cef
 shutdown
 shutdown
 shutdown
 ip address 50.58.x.82 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
 no ip address
 shutdown
 station-role root
interface Vlan1
 ip address 172.16.102.1 255.255.255.0
no ip http server
ip route 0.0.0.0 0.0.0.0 50.58.x.81
access-list 10 remark ACCESS PERMISSIONS
access-list 10 permit 192.168.0.0 0.0.255.255
access-list 10 permit 172.16.0.0 0.15.255.255
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 password 7 1111011C0D0812
 login
 transport input all
end
You need to -
1) add "ip nat inside" to vlan 1 interface
2) add DNS servers to your DHCP pool
Jon
Are you sure you can ping .81 from a laptop because that shouldn't work.
You don't have "ip nat inside" so it won't translate the 172.16.102.x IP and the ISP will not have a route for that subnet.
Can you post "sh ip arp"  ?
Jon
Here is the "sh ip arp"
CLTLVLTHREE#show ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  50.58.x.81            29   00a0.c86f.e57c  ARPA   FastEthernet4
Internet  50.58.x.82             -   001e.4ac3.7cd9  ARPA   FastEthernet4
Internet  172.16.102.1            -   001e.4ac3.7ccf  ARPA   Vlan1
Internet  172.16.102.100          4   000b.9731.9fc5  ARPA   Vlan1
Okay, that looks a lot better.
Still not sure how your laptop is pinging the .81 IP without NAT.
Anyway if you add the last changes I suggested do you get connectivity.
Jon
Ok Jon I added both changes you asked me to and here is what I am noticing coming from the hyperteminal interface I am able to ping the .82 interface (fa4) but not the default isp .81 router.
Also when I do an ipconfig  the dhcp service is working but there is no default gateway line...its blank.
Here is the config again:
Current configuration : 1685 bytes
version 15.1
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
   dns-server 216.136.95.2 64.132.94.250
   lease 7
ip cef
 ip nat outside
 duplex auto
 speed auto
 no ip address
 shutdown
 station-role root
interface Vlan1
 ip nat inside
no ip http server
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
The config looks correct now.
So are you saying when you get an IP address from the router on the laptop and then do an "ipconfig /all" you are not seeing a default gateway ?
Are you seeing the DNS servers ?
Jon
yep....the 2 dns servers are showing up from the isp but here is something that i noticed the dhcp server line shows 172.16.101.1 which is supposed to be the default gateway.
That is correct the DHCP server line should be the same IP.
I am getting a bit lost here, are you saying that there is just no default-gateway entry in ipconfig /all ?
Jon
Here is what I am seeing with ipconfig /all
Your comment about the 101 subnet is not in the config that subnet is the one that our corporate internal network is using which is how I am accessing the laptop through wireless.
I hope the picture will paint a clearer picture.
You can't have two default gateways for your client.
You didn't mention your laptop had another connection.
This won't work unless you can set the default gateway to be the router but by doing that I suspect you would lose connectivity to the laptop.
What you could do is pick an IP on the internet ie. 8.8.8.8 and then add a route for that IP to your laptop pointing to 172.16.102.1 and then at least you would be able to test IP connectivity.
Jon
Posting the output of ipconfig was very helpful to me. For one thing it helped me realize that I had not read some details carefully and had missed that both 172.16.101 and 172.16.102 are being used.
It is also helpful to know that the laptop is reporting connectivity for both its wireless interface and its wired Ethernet interface. I wonder if not having a default gateway indicated in the wired Ethernet interface reflects the fact that this is the second interface active on the laptop and the default gateway for the wireless takes precedence?
Can you post the output of route print which will help us to see which interface it is using when it attempts to ping?
Rick
Rick
Rick
I believe that is exactly what is happening ie. the router is sending the default gateway but the laptop simply doesn't use it because it already has one which is a logical thing to do.
I think the only solution is to add a temporary route just to test connectivity because if you change the default gateway you wouldn't be able to connect to it from the corporate network.
Jon
you both are correct and both very smart...I have since arrived at the location where the circuit is located and have disconnected the wireless altogether which foes along with you mentoning you cannot have two default gateways. Now that tha wireless is disconnected I am only connected to fa0 through mym laptop which ip address is 172.16.102.100 and now it is showing the default gateway as being 172.16.102.1.
However for some reason the internet is unattainable still, here is the updated config.
Current configuration : 1746 bytes
! Last configuration change at 00:50:02 UTC Fri Mar 1 2002
version 15.1
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
   lease 7
ip cef
 ip nat outside
 duplex auto
 speed auto
 no ip address
 shutdown
 station-role root
interface Vlan1
 ip nat inside
no ip http server
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
I think it is quite helpful to now have the laptop with only a single active interface. I do not see anything in the config that would impact Internet access. I would suggest that as a first test that you use the Hyperterm connection to the router console and ping the .81 address through the Hyperterm connection. That would be the router pinging to a connected subnet. If that ping does not work then we need to consider the possibility that the ISP device may be configured so that it will not respond to ping. In that case I like Jon's suggestion that you try to ping 8.8.8.8 (and perhaps configure a route for that address). After we get some success with the router doing the ping then we can test with ping from the laptop.
Rick
Rick
