rate-limit command on sub interface
SAM MUNZANI
I have following configuration on the router.
int g0/1
desc Customer # 1. Need to rate limit to 100Mbps bandwidth of internet connection
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip addr y.y.a.a 255.255.255.192
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
int g0/2
ip addr x.x.x.1 255.255.255.192
Other internal subnets, DMZ and some other customers
int g0/3
ip addr y.y.y.1 255.255.255.252
descr ISP facing interface
ip route 0.0.0.0 0.0.0.0 y.y.y.2
Scenario:
2 customers are connected via sub interface 10 and 20. 9 other customers connected via g0/2. Static routes are there in place to route to those customers via G0/2.
ISP connection is gigabit but I need to give 100Mbps to customer # 1 that is connected to g0/1.10. What's best way to achieve it? I need rate limiting in both directions.
Below is what I came up with that uses rate-limit commands and the router already took my commands. However none of the Cisco examples show sub interfaces so is it supposed to work with sub interfaces at all? OR I have to do rate-limit with ACL on main interface?
rate-limit input  100000000 18750000 37500000 conform-action transmit exceed-action drop
rate-limit output 100000000 18750000 37500000 conform-action transmit exceed-action drop
Thanks in advance,
0 Replies 0
