Cisco 871W Switch
dvinem671
I recently got a Cisco Switch 871W - I finally got it configured to my imac, but when I go into it to reset the admin password within the GUI it doesn't reset, and when I go into the terminal - I am not seeing it as it boots up. Does anyone have any idea how to get it reset - I have reset it using the reset button numerous times and have researched it- and have done the suggestions, but it just won't reset. THANKS! Trying not to allow this set back to deter me from getting the CCNA...
Mark Malone
so have not been on the GUIs but on terminal when you connect up does it ask you for a username when it finishes booting , or does it revert back to factory settings of like router >
There are multiple ways to set security/password on cisco so really need to know what your seeing first and then go from there
These devices come set with cisco/cisco as the passwords and when you first boot them and login it prompts you to change it , did you see that ?
even though this doc says 819 its the same for every 800 series so this may help , shows how to set password when your in
http://www.cisco.com/c/en/us/td/docs/routers/access/800/hardware/installation/guide/800HIG/initalconfig.html
Thanks I don't think I tried cisco/cisco so, I will give that a try. That is the interesting part I pull up Terminal and boot it up I don't see it at all. No loading, no POST, nothing. All the lights that are supposed to light up do I just get nothing - I know that is weird...
You should be seeing something on the terminal are you using correct baud rates and setup and correct adapter
https://www.youtube.com/watch?v=_xA94N__uzk
Thanks! I may have missed a step - I'll check it out and let you know!
