Cisco IOS NEC Intergration CAS Configu question
blackmichael
I am trying to connect a NEC DX system to a Cisco IOS router.  The NEC system T1 line is configure with a type of 24 channel CAS.  The config which is specifies is " Direct Inward Dialing (DID) Wink Start (DTMF and Dial Pulse) "
What would that be in the cisco world.  Its not "E&M&:  What setting should i use on my Router to interconnect
http://www.necdsx.com/library/80-160_t1.html
keglass
Level 7
Level 7
I am moving your post to the Enterprise Routing space in the Cisco Enterprise Networks community for more visibility and feedback.
Enterprise Routing
In addition, I recommend you also post this question to the Cisco Support Community for additional information.
https://supportforums.cisco.com/
I hope this helps. Thank you for participating in the community.
Kelli Glass
Moderator for Cisco Customer Communities
