09-21-2011 09:33 PM - edited 03-04-2019 01:41 PM
About twice a day (that I notice) my wireless loses its internet connection. All the wired machines continue to be connected to the internet but any wireless ones lose internet, though they maintain a connection with the router.
Can anyone point me in the right direction for figuring out what is going on?
Thanks!
09-21-2011 09:44 PM
Check the logs of the router. If your logs keep repeating how Dialer0 interfaces keeps going up/down then your DSL modem could need to be checked.
09-21-2011 11:30 PM
I am not seeing that or any other telling errors in the logs. BTW, when the wireless internet goes down the rest of the network still has internet.
09-23-2011 06:57 PM
Then do you see in your logs to show that the Dot11Radio0 goes up/down?
09-26-2011 11:05 PM
I am seeing an entry which says:
Packet to client 0012.0e64.ed38 reached max retries, removing client.
Does that sound like it could be it?
And to answer your question, no, nothing saying dot1 Radio goes down.
09-26-2011 11:07 PM
That error message normally means that the client has strayed too far away from the radio signal.
09-26-2011 11:15 PM
We often have 5-8 people connected and they all go down at the same time. The signal continues to be available but the internet cuts out. And I say the internet cuts out but this is only for wireless. The wired computers still have internet. Would you like to see a config file?
09-28-2011 02:36 AM
Can someone please take a look and tell me if they see something that might be causing this?
Thanks in advance.
version 12.4
no service pad
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
clock timezone London 0
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp excluded-address 10.10.10.61 10.10.10.254
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 202.78.97.41 210.4.2.61
lease 0 2
no ip ftp passive
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-3701369981
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3701369981
revocation-check none
rsakeypair TP-self-signed-3701369981
crypto pki certificate chain TP-self-signed-3701369981
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33373031 33363939 3831301E 170D3032 30333031 30303036
34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37303133
36393938 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100BA23 64291775 55A31863 4D4DD9DB 335EC076 A53DDA66 3DBE7FAD 1B3FE845
96409763 FD57E849 251DBBAC 1FE920A2 C93EE390 EEDE8AE6 5B7F8EB0 BF6BCA8B
BFD473A8 C0AB2B3E 5D48982D 1B3E98E4 07956320 EEFBA847 CC30AF35 B71E86C6
DE1E89E0 B4C35332 F59239A4 C52E59BB 6976BB18 DBCD157E A9DE2CDF D3BA974E
E5650203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
301F0603 551D2304 18301680 145DABA3 29D787B4 88CD7C95 513FA0F7 17CE27F9
47301D06 03551D0E 04160414 5DABA329 D787B488 CD7C9551 3FA0F717 CE27F947
300D0609 2A864886 F70D0101 04050003 81810055 8DDF9D38 2696DD8A 79A1C8B2
D8DA523D 8150284F 8849AFD2 F7CC1157 3F38CCC7 49EB6971 3B12961F 2DCDD671
A8AA16C5 77604069 F0DBAE79 EE868011 A65A3C51 F3FAAB2D 9615424F C34D95F9
80CEF7DC 447A628F 5D5F3976 8F891311 A894DC69 80980F84 28FBE854 76D0C896
12CE5B68 3E4973F3 679F809F 1E13C506 F3CEFB
quit
username
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ETH-WAN$
ip address 121.97.75.118 255.255.0.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
ip flow ingress
ip flow egress
encryption vlan 1 mode ciphers tkip
ssid MBG
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 test1234
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 121.97.75.117
ip flow-export destination 10.10.10.32 2055
ip flow-export destination 192.168.0.105 2055
ip flow-top-talkers
top 40
sort-by bytes
cache-timeout 1000
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip dns server
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
snmp-server ifindex persist
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CCCCCCCCCCCCCCCCC
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username
no username cisco
Replace
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
