Cisco 876
kvnmurthy
Please tell me how to configure Fast ethernet ports in 876 router.
Unable to assign ip address to the ethernet prots.
sh ip int outputs
FastEthernet0 is up, line protocol is down
Internet protocol processing disabled
FastEthernet1 is up, line protocol is down
FastEthernet2 is up, line protocol is down
FastEthernet3 is up, line protocol is down
mohammedmahmoud
Level 11
Level 11
Assign each interface to a specific vlan then configure the IP address under the SVI interface:
1.Create the VLAN:
vlan database
vlan x
exit
2.Assign an interface to a VLAN:
interface fastethernetx
switchport access vlan x
Assign an IP to the SVI interface:
3.interface vlan x
ip address x.x.x.x x.x.x.x
HTH,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
1.Create the VLAN:
vlan database
vlan x
exit
3.interface vlan x
HTH,
Mohammed Mahmoud.
Thank you it worked.
You are very welcomed, and thank you for using the rating system.
HTH,
Mohammed Mahmoud.
