Cisco 877 ATM interface "hangs"
I have a number of 877 routers used for ADSL backup, intermittently the ATM interface hangs cannot access the internet at all, the only way to start the ATM again is to do a "Clear int atm0" command
the Versions of IOS running are ADVSECURITY 124-4.T3, 124-6.T6 , and 124-6.T7
relevenent part of config below
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
no shut
interface Dialer1
bandwidth 256
ip address negotiated
ip access-group 130 in
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxx
ppp chap password yyyyyy
crypto map IPSec-VPN1
I have tried to see what is happening with debugs, but don't seem to be able to capture anything relevent
please advise.
paolo bevilacqua
Hi, please upgrade ADSL firmware:
ftp://ftp.cisco.com/pub/access/800
The one you want is 3.0.x, there is a doc on how to install it.
Ok . I had started to download later IOS anyway, but just upgrading the firmware saves a bit of time
