Cisco 877 - cisco commands undocumented -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-10-2009 01:42 AM - edited 03-04-2019 06:00 AM
A few times ago I enable `service internal` and then with a special command I show the product history and ( the most important thing ) if the router is refurbished and some comment about the reparation... Does anyone known this command ? Thank you!
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-10-2009 02:17 PM
service internal command activates some Cisco commands normally used for internal testing. Turning it on in global configuration mode allows you to view some previously hidden commands. Turn it on
by default and you will eventually find some extras.
USE THIS COMMAND AT YOUR OWN RISK.
