Cisco 877 Disabling Firewall
dilipchauhan
Hi, Is there any way to disable/switch off the firewall on a Cisco 877 ADSL router so all traffic is allowed in an out?
ahmednaas
Level 4
Level 4
Firewall functionality on a router is not on by default. You have to setup the firewall by issuing commands to tell the router how to filter traffic.
So basically if you remove all access lists and "ip inspect" statements, you have turned the firewall off.
