Cisco 877 router - Allow PING/SSH to BVI interface via DSL link
xianglind
Hi There,
I am trying to configure a cisco 877 router, with DSL bridge mode. I want to create an IP interface on the router that allows user to ping or ssh to it over the internet via DSL interface.
I have the following config: I can ssh to BVI interface via local FE port, however, users on the other end of the network (over ADSL network) is not able to ping the BVI IP address.
Could you please help me check if the config is correct?
no service pad
hostname CardaxTest
boot-start-marker
boot-end-marker
enable secret 0 cisco
no aaa new-model
resource policy
ip cef
ip domain name cardax.com
crypto key generate
1024
ip ssh version 2
username cisco privilege 15 secret 0 cisco
bridge irb
interface ATM0
 no ip address
 no atm ilmi-keepalive
 pvc 0/109
  encapsulation aal5snap
 dsl operating-mode auto
 bridge-group 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
 no ip address
 bridge-group 1
interface BVI1
 ip address  <<IP_address Mask>>
 ip virtual-reassembly
ip route 0.0.0.0 0.0.0.0 ATM0
ip route <<Network_address Mask>> BVI1
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
 password cisco
 login
 no modem enable
line aux 0
line vty 0 4
 login local
 transport input ssh
scheduler max-task-time 5000
the BVI IP address needs to be the default gateway for all your clients. The below config should allow your server and LAN clients to ping the BVI:
no service pad
hostname CardaxTest
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
crypto key generate
1024
ip ssh version 2
bridge irb
interface ATM0
no ip address
pvc 0/109
pppoe-client dial-pool-number 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.11.146.240 255.255.254.0
interface Dialer0
description --- Internet ADSL ---
ip address negotiated
ip mtu 1460
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 10.0.0.0
no ip http server
control-plane
bridge 1 route ip
line con 0
password cisco
login
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
6 Replies 6
with your current configuration, your router is not set up for Internet access at all. What do you want to accomplish, to have the BVI get the public IP address ?
Below is a configuration that should at least give you Internet access. Try to establish that first...
no service pad
hostname CardaxTest
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
crypto key generate
1024
ip ssh version 2
bridge irb
interface ATM0
no ip address
pvc 0/109
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip nat inside
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password
ip nat inside source static tcp 192.168.1.1 22 interface Dialer0 22
access-list 1 permit 192.168.1.0
no ip http server
control-plane
bridge 1 route ip
line con 0
password cisco
login
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
Thank you for your reply. the purpose is to use this modem to carry some traffic from LAN interface to a server in the network. I don't need internet access, at least not to the public internet.
So I have some devices connects to FE port on the 877, and 877 connects to a DSLAM, then the DSLAM connects to a server.
I just want to configure a simple bridge, and asign an IP address to the 877 for troubleshooting purpose. So ppl at server end can ssh or ping the 877.
At the moment, the end device talks to the server OK. Server can ping end devices behind the 877, but cannot ping 877's IP addresss.
understood. So basically, the BVI is your layer 3 interface. What is the IP address you have assigned to the BVI ? Is that in the same address space as the server and the LAN devices ?
IP address on BVI is 10.11.146.240/23 and server and LAN device IP are within the same subnet.
no service pad
hostname CardaxTest
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
crypto key generate
1024
ip ssh version 2
bridge irb
interface ATM0
no ip address
pvc 0/109
interface Vlan1
no ip address
bridge-group 1
interface BVI1
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password
no ip http server
control-plane
bridge 1 route ip
line con 0
password cisco
login
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
Hi Georg,
I have tested my config in lab, and it seems to be working. i am able to ping the BVI interface from DSLAM side.
But in real network, we have some firewalls and routers in place between server. Probably it's once of those devices blocking the traffic. :)
Thanks a lot for your help,
Xianglin
