Cisco 877 Wireless router connection problems
JacquesLayman
Sorry if the is posted in the wrong community. Can anyone please help me out?
I have a Cisco 877w router and is trying to configure it for ADSL. It manage to connect but disconnect every few seconds just after it connected.
While connected I am able to go to websites but before I can do anything further it disconnects.
Any help will be greatly appreciated.
Attached is the configuration that I currently have
Jacques
You may wish to remove
 ppp pap sent-username XXXXXXXXXXXXXXX password 0 XXXXXXXXX
from the dialer interface most ISP's support CHAP
I'd also suggest adding ip tcp adjust-mss 1452
 to the dialer interface
does show logging give any information?
you may need to run some debugs like
debug pppoe errors
debug pppoe events
to gather some more info however remember to issue undebug all ( u all) to turn off debugging
