Cisco 877VA and SIP service - inbound call possible outbound not possible
cristian.a
Hi Guy , like in description I have this problem with a Cisco 877va and a Grandstream with a SIP service . I have chose the simply way to work with this system but I canot solve the question. THe sip phone is located on address 192.168.1.54 Configuration is :
Andromeda_887VA-K9#sh config
Using 3189 out of 262136 bytes
! Last configuration change at 17:21:03 GMT Fri Feb 2 2018 by Quasar
version 15.4
hostname Andromeda_887VA-K9
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone GMT 1 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
crypto pki trustpoint TP-self-signed-2909530827
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2909530827
revocation-check none
rsakeypair TP-self-signed-2909530827
crypto pki certificate chain TP-self-signed-2909530827
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
ip dhcp excluded-address 192.168.1.1
ip dhcp pool Data_pack
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 83.37.17.51 85.38.28.97
ip name-server 83.37.17.51
ip name-server 85.38.28.97
ip cef
no ipv6 cef
cts logging verbose
license udi pid C887VA-K9 sn FCZ2049E2KG
username Qxxxxxx privilege 15 password 0 xxxxxxxxxxxxxxxx
controller VDSL 0
operating mode vdsl2
modem PTM
interface ATM0
no ip address
ip flow ingress
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
interface Ethernet0.835
encapsulation dot1Q 835
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip nat inside
no ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
mtu 1492
ip address negotiated
no ip redirects
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname timadsl
ppp chap password 0 timadsl
ppp pap sent-username xxxx password 0 xxxx
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.1.54 5004 interface Dialer0 5004
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 permit ip any any
access-list 100 permit tcp any any eq www
access-list 100 permit udp any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
Please someone can help me ? Thank you
I think SIP uses 5060. 5004 is for RTP. Also, encrypted SIP uses 5061. Try and add all of the below to your config:
ip nat inside source static udp 192.168.1.54 5004 interface Dialer0 5004
ip nat inside source static tcp 192.168.1.54 5060 interface Dialer0 5060
ip nat inside source static tcp 192.168.1.54 5061 interface Dialer0 5061
ip nat inside source static udp 192.168.1.54 5060 interface Dialer0 5060
ip nat inside source static udp 192.168.1.54 5061 interface Dialer0 5061
Many many  thanks friend, yes work . I tested for a couple of day !! Thank you again (Y)
