cisco 877w http ip address.
wangkiantjun
the title above, how and what command i should type to set http server ip address inside cisco 877w in order to meet requirement for cisco configuration professional 2.3. what type of physical port i can use after setting http server ip address inside cisco 877w.
i found the sample command, and i did set the username & password for privilege level 15
but after i edit it still not working.
what kind of port i should connect once the http server ip address inside cisco 877w is working.
thanks.
Surendra BG
its..
ip http server or ip http secure-server
username privelege password
ip http authentication local
Lemme know how this answered your question...
Surendra
Surendra BG
