Cisco 877W - no wireless connection
marekpro607
I'm just beginning the adventure with cisco - I bought a 877W, I configured, the internet works but only after the cable - wifi connection is detected by the laptop, but can not connect (yellow triangle)
I tried several configurations but none was positive.
my sh run:
[code]
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname cisco
boot-start-marker
boot-end-marker
enable secret 5 $1$eCNp$rWuBfZ/cexnwnkm7L447s.
aaa new-model
aaa session-id common
dot11 syslog
dot11 ssid ciscowifi
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 0 password
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.56.1
ip dhcp pool CLIENT
   import all
   network 192.168.56.0 255.255.255.0
   default-router 192.168.56.1
   dns-server 8.8.8.8 194.204.159.1 194.204.152.34
   lease 0 2
no ip domain lookup
username marek password 0 password
archive
 log config
  hidekeys
ip tcp path-mtu-discovery
interface ATM0
 description Polaczenie ADSL do ISP
 no ip address
 no atm ilmi-keepalive
 pvc 0/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
 dsl operating-mode auto
 hold-queue 224 in
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
 no ip address
 no ip redirects
 ip local-proxy-arp
 ip nat inside
 ip virtual-reassembly
 no dot11 extension aironet
 encryption vlan 1 mode ciphers tkip
 encryption mode ciphers aes-ccm tkip
 broadcast-key change 3600
 ssid ciscowifi
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 world-mode dot11d country AU indoor
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.1
 description ciscowifi
 encapsulation dot1Q 1 native
 no cdp enable
 bridge-group 1
interface Vlan1
 description Polaczenie dla sieci LAN
 ip address 192.168.56.1 255.255.255.0
 ip nat inside
interface Dialer0
 description Interfejs dzwoniacy
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp chap hostname ..............@neostrada.pl
 ppp chap password 0 .................
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
access-list 100 permit ip 192.168.56.0 0.0.0.255 any
access-list 100 deny   ip any any
no cdp run
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 transport preferred ssh
 transport input ssh
scheduler max-task-time 5000
end
[/code]
Can anybody help me?
Thanks in advance
ghostinthenet
Level 7
Level 7
Wireless VLANs and wired VLANs are two different animals and don't talk to each other unless you manually bridge them. Try bridging the two into one network like this:
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
default interface Vlan1
interface Vlan1
 bridge-group 1
interface BVI1
 ip nat inside
Make sure you configure this from the serial console. Doing it from the LAN won't work because you'll be cut off as soon as you clear the VLAN 1 configuration.
ghostinthenet
Level 7
Level 7
bridge irb
bridge 1 route ip
interface Vlan1
 bridge-group 1
interface BVI1
 ip nat inside
Now everything is working properly - very very thanks!
