Cisco 877W VPN Access
guy.tipton
I am having problems VPN into my 877W to remore control, you can PPTP through it but cannot access this remotely, can this be a script issue?
spremkumar
Level 9
Level 9
hi
what you are not able access after you get onto PPTP ?
Aren't you able to access the internal resources ?
If possible can you post the config of your router here ?
regds
Correct!
No, cannot establish a connection to Cisco VPN
If possible can send me your config of your router here ? please find attached
Rgds
Guy
