Cisco 878 No Carrier Detect LED
j.spenceley
I have a SDSL G.DMT service with Zen. We have purchased an 878 and put a config on it with SDM but it refuses to show even a CD led when connected up to the phone line.
I've also followed the "PPP over ATM with NAT" configuration guide line by line that hasn't helped.
The SDSL does work and we are currently using a Speedtouch 605s.
Has anyone got a sample config for the controller which shows all the lines needed to get a carrier detect from a UK supplier.
Joe
Hello
Maybe you can try changing the operating-mode.
The next lines are a basic config for SDSL in Belgium:
interface ATM0
dsl equipment-type CPE
dsl operating-mode GSHDSL symmetric annex B
dsl linerate auto
no shutdown
Fred
s-doyle
Level 3
Level 3
Reasons could be hardware fault on the SHDSL port of the 878. Is it possible for you to test the 878 router on another SDSL line.An incompatibility issue between the Cisco 878 and the DSLAM used by the ISP.Refer URL
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
Hello
interface ATM0
dsl linerate auto
no shutdown
Fred
Hi Fred,
Thanks for the reply, but I have now got it working.
Cheers,
Joe
