Cisco 880G and Software Device manager
kouliscon
Hello
i have a cisco router device 880G and i would like to add more security to my firewall by restricting some websites lets say and i find out that i can use the Software Device Manager.
I download the software to my computer and there i had 2 options.
1) to install it at the router directly
2) to install it locally.
For installing to router it didnt work. Does anybody knows if it is compatible? or which software is compatible and does the same things?
Locally it opens a windows where i put the ip of the router and then the iexplorer 9 opens which i have at my laptop,
then it says about "nternet explorer restricted this webpage from running scripts or Active x" and if i press the allow blocked contents then another window opens with some code...
anybody knows what i have to do?
thx in advance.
Leo Laohoo
Maybe because your router does not have enough flash space.
Hello
finally after looking at the Cisco website i found out and i installed CISCO CONFIGURATION PROFESSIONAL 2.6 and that did the job. Is a similar program as Software Device Manager which is not support from 880G 3G.
thx
