cisco 881 cant access internet
cardmaker
Hello, from console i cant ping google.com or ping 4.2.2.1 form my router.
here is my config
Current configuration : 1976 bytes
version 15.3
hostname cisco
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 $1$MIpR$pornU7ZCXJR68ina5z7sV1
no aaa new-model
ip dhcp excluded-address 10.0.0.100 10.0.0.150
ip dhcp excluded-address 10.0.0.20
ip dhcp pool net
 network 10.0.0.0 255.0.0.0
 default-router 10.0.0.1
 dns-server 10.53.XX.XXX
ip dhcp pool rede
 import all
 dns-server 212.1XX.XX.XX
ip cef
no ipv6 cef
license udi pid C881-K9 sn XXXXXXXXXXXX
username dom password 0 cisco
interface FastEthernet0
 switchport access vlan 2
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address dhcp
 ip nat outside
 ip nat enable
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan2
 description Connection to SW1
 ip address 10.0.0.20 255.0.0.0
 ip nat inside
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source list 101 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4
access-list 101 permit ip 10.0.0.0 0.255.255.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
 password cisco
 login
 transport input all
line vty 5 15
 password cisco
 login
 transport input all
scheduler allocate 20000 1000
end
my ISP is cable modem and ip dhcp, any sugestions?
23 Replies 23
Hello
Can you try the following:
no ip nat inside source list 1 interface FastEthernet4 overload
no ip route 0.0.0.0 0.0.0.0 FastEthernet4
no ip nat enable
no ip dhcp pool rede
ip route 0.0.0.0 0.0.0.0 DHCP
ip dhcp pool net
 import all
sh ip dhcp import
res
paul
Kind Regards
Paul
whit yours comands it worked for some time and then no ping again,
here again my config
cisco#sh run
cisco#sh running-config
Building configuration...
Current configuration : 1818 bytes
version 15.3
hostname cisco
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp pool net
 import all
 dns-server 10.53.xx.xxx
ip cef
no ipv6 cef
license udi pid C881-K9 sn xxxxxxx
 no ip address
 no ip address
 no ip address
 no ip address
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan2
 ip nat inside
ip http server
ip route 0.0.0.0 0.0.0.0 dhcp
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 password cisco
 login
 transport input all
line vty 5 15
 password cisco
 login
 transport input all
end
the ping 4.2.2.1 result is
cisco#ping 4.2.2.1
Sending 5, 100-byte ICMP Echos to 4.2.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 736/768/792 ms
and ping google
cisco#ping google.com
Translating "google.com"...domain server (10.53.0.235) (10.53.0.236)
% Unrecognized host or address, or protocol not running.
Hello
ip dhcp pool net
 default-router 10.0.0.20
 No dne-server 10.53.xx.xxx
sh IP dhcp input
res
paul
Kind Regards
Paul
this time only worked one time afther your comands and reloaded router. here the result
Translating "google.com"...domain server (10.53.0.235) [OK]
Sending 5, 100-byte ICMP Echos to 216.58.210.142, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 624/680/736 ms
cisco#
here the new config
Current configuration : 1794 bytes
version 15.3
hostname cisco
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp pool net
 import all
ip cef
no ipv6 cef
 no ip address
 no ip address
 no ip address
 no ip address
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan2
 ip nat inside
ip http server
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 password cisco
 login
 transport input all
line vty 5 15
 password cisco
 login
 transport input all
end
Hello
Are you still having connectivity problems?
res
Paul
Kind Regards
Paul
hello, yes i still having connectivity problems.
Hello
Do you have internet access now?
Where is the connection failing - on the router or from a client pc?
res
Paul
Kind Regards
Paul
i just have internet access in a few moments afther execute yours commands.
then pass some minutes i dont have anymore acess to the internet.
the connection is failing in the router.
Hello
In your OP you stated
"From console i cant ping google.com or ping 4.2.2.1 form my router."
Can you ping anything on the internet - or have no access whatsoever?
res
Paul
Kind Regards
Paul
cisco#ping 4.2.2.1
*Apr 20 17:27:12.551: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed state to up!!!
Success rate is 100 percent (5/5), round-trip min/avg/max = 620/716/800 ms
the ping 4.2.2.1 is ok but nothing for the rest.
Hello
Do hostname  resolution isnt working ( dns)
can you post
Sh ip dhcp import
res
Paul
Kind Regards
Paul
Hello
So hostname  resolution isnt working ( dns)
can you post
Sh ip dhcp import
res
Paul
Kind Regards
Paul
here you the answer:
cisco#sh ip dhcp import
Address Pool Name: net
Domain Name Server(s): 10.53.0.235 10.53.0.236
Hello
Looks like you dns is inappropriate -
can you try adding dns to your dhcp pool.
ip dhcp pool net
dns-server 8.8.8.8 8.8.4.4
and test again
res
Paul
Kind Regards
Paul
