Cisco 881 cant to obtain ip from ISP dhcp-server
kallugin2011
Hi. I cant to obtain DHCP-address on WAN interface. All over hardware can (windows-based systems and Asus RT-N10), but not Cisco 881
Also i cant to obtain ip even from Asus RT-N10 with this configuration:
version 15.1
service config
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1523C3RR
username admin privilege 15 secret 5 $1$0H8v$xx/HtPJIllcFvEWFjzI5t/
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip broadcast-address 0.0.0.0
duplex auto
speed auto
interface Vlan1
ip address 192.168.4.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
transport input all
end
After thousands experiments next configuration started to obtain ip from Asus RT-N10 , but not from ISP
! Last configuration change at 12:22:25 UTC Tue Sep 13 2011 by admin
version 15.1
no service pad
hostname Router
boot-start-marker
boot system flash c880data-universalk9-mz.151-3.T.bin
boot-end-marker
no aaa new-model
ip source-route
ip dhcp relay information trust-all
ip dhcp compatibility suboption link-selection standard
ip cef
no ip dhcp-client broadcast-flag
no ipv6 cef
username admin privilege 15 secret 5 $1$3bFL$y/cxqQLd.8cixPrtETEJ4.
ip dhcp relay information trusted
ip dhcp relay information check-reply none
no ip dhcp client request tftp-server-address
no ip dhcp client request netbios-nameserver
no ip dhcp client request vendor-specific
no ip dhcp client request static-route
ip address dhcp
duplex auto
speed auto
interface Vlan1
no ip address
no ip http server
logging esm config
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
transport input all
end
ISP's hardware based on Juniper.
What else must I switch of/on to start DHCP-client?!
5 Replies 5
cadet alain
are you doing PPoE with your ISP ? if so then you must obtain IP address from IPCP part of PPP with the ip address negotiated command  under the ethernet interface and you must configure a dialer interface and  bring up the 2.
There are lots of configs here on this forum if this is your case.
Regards.
Alain.
No, its not PPOE process, just direct Ethernet connection. But dhcp.
ip address dhcp
duplex auto
speed auto
- its all what I need to work. But its not work on 881
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t8/feature/guide/gtdhcpcf.html didnt help me
ok so do a debug on the 881. you can debug ip packet 199 detail where 199 is the following ACL:
access-list 199 permit udp any any bootps
access-list 199 permit udp any bootpc any
you can also debug DHCP with debug dhcp detail
But before doing this be sure you released any ISP served address from other router which you've got from less than 24 hours. then try again and if it still fails then do the debugs I told you about above.
Regards.
Alain.
We purchased another one Cisco 881 today, and new one working properly with same IOS and same configuration. Im shoked. No any versions. Even i used same MAC-address.
steini
Hi together,
I had similar strange behavior.
Somtimes i got unexpected config additions like
So i removed that entry, but it cames back.
if i executed follwing command, i was able to get an IP once.
conf t
int fa4
ip address dhcp client-id FastEthernet 4
ip broadcast-address 255.255.255.255
This is happend when in the romon Mode (Console->Break@boot->confreg->enabled are:use all zero broadcast) is enabled.
since i disabled it, no ip broadcast-address 0.0.0.0 additions where made :-)
and the DHCP Broadcast are 255.255.255.255.
SecondCase:
Some ISP's dont like The ClientsID that are generated with the "ip address dhcp" - take a look with wireshark.
With the option "ip address dhcp client-id FastEthernet 4" the Client ID is set to the Mac Address of this interface.
Best Regards
steini
