Cisco 881 - Cellular Interface with dialer
HOT HOT
Hi Everyone,
I have a cisco router 881 with Cellular interface to backup the Fa4 connection
I was Configured the Interface dialer 1 on my 881 but when I'm configuring the interface cellular and typing the command:
"dialer-group 1" I'm getting the error: "%Remove Dialer Profile Configuration first".
show version:
System image file is "flash:c880data-universalk9-mz.151-4.M3.bin"
Cisco 881G2 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FTX161387H9
5 FastEthernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 Cellular interface
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C881G-U-K9            FTX161387H9
show ip interface brief:
Interface                  IP-Address      OK? Method Status                Protocol
Cellular0                      unassigned      YES unset  down                  down
Dialer1                         unassigned      YES manual up                       up
FastEthernet0              unassigned      YES unset  up                         up
This is the configuration of the interface cellular0:
interface Cellular0
 no ip address
 ip virtual-reassembly in
 zone-member security Untrust
 encapsulation ppp
 dialer in-band
 dialer pool-member 1
 async mode interactive
 no ppp lcp fast-start
end
This is the configuration of the interface dialer 1:
interface Dialer1
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 0
 dialer string xxx
 dialer-group 1
 ppp chap refuse
 ppp pap sent-username xxx password 7 XXXXXXX
 no cdp enable
end
I was trying to remove the int dialer1 and type the command "dialer-group 1" under the interface cellular0 but I got the same error.
What am I doing wrong?
22 Replies 22
I have a router that works fine and this is his profile
RTR881G#show cellular 0 profile
Profile password Encryption level: 7
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = 192.168.17.43
Access Point Name (APN) = xxx
Authentication = None
Username:
Password: 10
 * - Default profile
Configured default profile for active SIM 1 is profile 1.
What you say about this router?
it is possible that your provider doesn't require authentication.
Since you have a working router, what does the chat script look like on that one ?
Is that router connected to the same provider ? Not all chat scripts work the same for all providers. Can you post the working one and the one from your 881 (the one that is not working) ?
chat-script xxx""  "ATDT*99*1#" TIMEOUT 30 "CONNECT"
this is my chat-script
do a 'debug chat' to see if the chat script is working. You also might want to try this one, it depends on the kind of modem you have in your router:
chat-script xxx "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
Can you post a 'sh version' ?
Gpauwen
I posted on the information you need on my first comment
show version:
1 terminal line
License Info:
License UDI:
Device#   PID                   SN
try the new chat script and SLIP encapsulation. It would look like this:
chat-script hot "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
interface Cellular0
encapsulation slip
dialer in-band
interface Dialer1
no ip address
ip virtual-reassembly out
encapsulation slip
dialer pool 1
dialer string hot
dialer persistent
dialer-group 1
What doe's it means?
Why did you change the chat script and the encapsulation?
It is just a suggestion, maybe it works with that configuration...
