Wireless AP crash
S.ashok S
I have Cisco 2504 controller with 15 AP licence but one of the AP is disconnecting from the controller.
After logged into PoE switch, giving shut and no shut on problematic AP connected switch port then it getting UP and after some time the issue is repeating. Many access points are connected on that switch, no issues with those but one of the ap is getting issue.
Copied the carsh report from the controller and attached the same. Kindly help to resolve the issue.
Ashok
try to manually bind the AP to the controller:
AP#capwap ap primary-base controller_name ip-address
Can you post the config of the AP ?
Thank you for your reply.
AP is configured with static IP and Controller IP address but still getting the issue.
Thanks and regards,
Ashok
