Cisco 881 ipsec vpn
richard064
I have purchased a Cisco 881 router, and need to setup IPSEC VPN. It was purchased in New Zealand from a supplier listed on the Cisco website.
Do I need to upgrade the software on this router to be able to create the VPN?
Or do I need to buy a license?
I have tried talking to Cisco support, but they have been very unhelpful.
15 Replies 15
Tagir Temirgaliyev
you need C881/K9 it supports  IPSEC VPN.  3des. but Iam not shure aes256
Please post the output of sh ver | i License Level
You need to have "advsecurity" or "advipservices" for IPsec VPNs.
Hi it shows.
License Level: advsecurity_npe   Type: Permanent
But show crypto isakmp policy
Gets Invalid input detected at '^' marker
cheers rich
advsecurity_npe
NPE stands for "no payload encryption". You need a version without "NPE".
I have purchased an advipservices license and installed it.
But it says not deployed and the advsecurity_npe version is still enabled.
Not sure how to disable the advsecurity_npe version, no obvious way to do in from ccp.
cheers rich
npe means like without crypto
you need to accept licence agrement and to purchase licence and to set up crypto
licenc boot modul  c881 tec sec
Ok how do I do that?
Is that a command I need to run?
Or do I need to buy a license from Cisco?
I have tried asking Cisco what I need but they don't help.
It has been a frustrating experience, because I brought this router from a company on Cisco's list here in New Zealand.
And I told them at the time what I needed the router to do.
I your appreciate the help guys.
cheers rich
Hi there
I have the same problem I can not get to the bottom of what is needed to enable all the Crypto commands but it is related to advsecurity.  I would like to know what I need to do to enable these features
You added your question to a very old discussion. So lets start by verifying that you do have really the same problem. Please post the output of show version so we can verify whether the image is npe. Assuming that you do have the same issue then I believe that the solution has two parts. You need a license that supports encrypted payload and then you need an image file that supports encrypted payload.
Rick
Rick
Hi Rick
Thanks for this show version out put follows
OIS-02-VDSL>show version
Cisco IOS Software, C800 Software (C800-UNIVERSALK9_NPE-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 16:14 by prod_rel_team
ROM: System Bootstrap, Version 15.2(3r)XC, RELEASE SOFTWARE (fc1)
OIS-02-VDSL uptime is 6 days, 22 hours, 48 minutes
System returned to ROM by reload at 14:34:31 UTC Tue Feb 12 2019
System image file is "flash:c800-universalk9_npe-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com .
Cisco C897VA-K9 (revision 1.0) with 488524K/35763K bytes of memory.
Processor board ID FCZ175090DV
1 DSL controller
1 Ethernet interface
9 Gigabit Ethernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C897VA-K9 FCZ175090DV
License Information for 'c800'
License Level: advsecurity_npe Type: Default. No valid license found.
Next reboot license Level: advsecurity_npe
I think I have purchased and installed FL-SSLVPN10-K9 but this does not seem to enable the crypto commands - any help you can give would be much appreciated
Thanks for the output of show version. It does confirm that you do have the same problem. As I mentioned the solution is a 2 part thing. Getting a license to support encrypted payload is part of the solution. The other par of the solution involves the image file. Here is what you have
You need to download and install an image file that does support payload encryption. If you have privileges to download software from the Cisco site then download a new image with the encryption capability. If you do not have privileges to download software you may need to work with who ever sold you the new license to get the image file. Or you might open a case with Cisco TAC and see if they can help you obtain the correct image file.
Rick
Rick
Thanks for this
"Or you might open a case with Cisco TAC and see if they can help you obtain the correct image file.” Can you tell me what Cisco TAC is and how I would contact them please
TAC stands for Technical Assistance Center. If you are in the US or Canada you can reach them at this number 1-800-553-2447.  If not in US or Canada you can go to the Cisco web site and follow the link for support to find other phone numbers. Or you could use this link for support
If you have a support contract for your router you have the right to open cases and get their help. If you do not have a support contract but purchased a license you can request their help and I hope that they would (but sometimes they get very strict about the contract requirement).
Rick
Rick
Thanks Rick
