PPPOE configuration in cisco 881w router
jawharcisco
Can any one help me to configure the PPPOE in FE interface on the mentioned router?
Regards ,
Jawhar.
Mark Malone
what are you using chap or pap from ISP ? Did you get there credentials you will need them to authenticate on their line
Do you have a fixed public ip address or dynamic off them ?
11 Replies 11
Mark Malone
HI Mark
Thank for your respond .
ISP provided me the credentials to authenticate the PPPOE and we dont have fixed public IP ,its dynamic only
Jawhar
This is what you need obviously replace your ips , acl no etc and add your passwords and stuff but the syntax is what you need for pppoe to connect to ISP negotiate authentication and then pull itself an ip address
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
description My LAN Interface
ip address 10.10.10.1 255.255.255.0
ip nat inside
no ip mroute-cache
no cdp enable
interface Ethernet1
description Physical ADSL Interface (Facing the ISP)
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
description Logical ADSL Interface
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname [your username, provided by ISP]
ppp chap password 0 [your username password, given by ISP]
ip nat inside source list 10 interface Dialer1 overload
no ip http server
ip classless
access-list 10 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
did you have any luck getting it up and running
Hii
First of all  thanks for your support ,
As per the above configuration, i can enable vpdn but unable to configure pppoe under vpdn , then i tried the below configuration and the link became up and running
Building configuration...
Current configuration : 2693 bytes
! Last configuration change at 13:49:09 UTC Tue Jan 5 2016
! NVRAM config last updated at 14:23:24 UTC Tue Jan 5 2016
version 15.1
no service pad
hostname FRG
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp pool FUR
network 192.168.8.0 255.255.255.0
default-router 192.168.8.1
dns-server 4.2.2.2 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO881W-GN-E-K9 sn FCZ1651C2KV
crypto ipsec client ezvpn
connect auto
group  key
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description #phisical WAN interface #
bandwidth inherit
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
hold-queue 224 in
interface Virtual-Template1 type tunnel
no ip address
tunnel mode ipsec ipv4
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
ip address 192.168.8.1 255.255.255.0
ip nat inside
interface Dialer0
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
ip verify unicast reverse-path
encapsulation ppp
ip tcp adjust-mss 1400
load-interval 30
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname
ppp chap password
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 10 permit 192.168.8.0 0.0.0.255
line con 0
password
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
password
login
transport input all
end
Jawhar .
Ah great glad you got it sorted , some of the ISPs use that vpdn group but its not a necessity all the time as you seen for your setup :)
Thanks for your info.
riaanptrs
Hi Guys,
I'm trying to configure PPOE on the WAN interface of the cisco 881w router.  Issue is the WAN interface needs to be on VLAN 10.  Can anyone advise?
you need to use a subinterface. Post your current configuration so we can fill in the necessary bits and pieces...
Hi thanks I'll try the subinterface and will let you know if I come right. BTW do you know if I can do ICND 1 and ICND2 and then become CCNA. Also I am actually CCNA certified but cert has expired. Can I go that path to renew my certification?
subinterface should look like below.
interface FastEthernet4.10
encapsulation dot1q 10
bandwidth inherit
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
hold-queue 224 in
