Cisco 881 k9 Router Blocks Access to Website
okoroji80
Dear Support team i have a Cisco 881 k9 box that does not allow access to a particular Website.
how could i address this issue.
I have the following Access-list on the router:
ip nat inside source list 110 interfa
ip route 0.0.0.0 0.0.0.0 197.255.52.89
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 110 deny   ip 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
18 Replies 18
Richard Burts
Are you telling us that you have successful access to other web sites and that one web site does not work? Would you post the output of an attempt to ping to that web site? Would you post the output of nslookup for the name of the website?
Rick
Rick
Yes i have access to other websites.
A ping to the said site timed out
Part of the questions that I asked was to try to determine whether the problem is with DNS name resolution or is about IP connectivity. Your response gives me no information about that. Please post the outputs that I requested.
Rick
Rick
CADD#ping www.caddcentreng.com
Translating "www.caddcentreng.com"
% Unrecognized host or address, or protocol not running.
The above is a response from a ping to the website
below is the Ip address of the website
CADD#ping 192.64.112.59
Sending 5, 100-byte ICMP Echos to 192.64.112.59, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 196/208/224 ms
CADD#
p forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 110 interface FastEthernet4 overload
access-list 110 permit ip 192.64.112.0 0.0.0.255 any
no cdp run
ip cef
no ip domain lookup
ip domain name www.caddcentreng.com
no ipv6 cef
THIS IS THE ERROR MESSAGE DISPLAYED WHEN ONE TRIES TO OPEN THE WEBSITE FROM WINDOWS
XML Parsing Error: unexpected parser state Location: jar:file:///C:/Program%20Files/Mozilla%20Firefox/omni.ja!/chrome/toolkit/content/global/netError.xhtml Line Number 311, Column 58:
&netInterrupt.longDesc;
That would appear to be a browser issue rather than the router blocking access to the website. Try opening Firefox in safemode and access the website then.
Thank you for the outputs that I requested. This one is quite helpful and does demonstrate that the problem is a failure with DNS
If you can not resolve the name then your browser will not be able to access the web server..
Rick
Rick
you've got no ip domain lookup   configured so it will never try to translate the name to IP.
You can try with a site that is working and see that the ping for the name fails on the router too.
So this doesn't demonstrate that your problem with accessing the site is a DNS problem.
You should ping the name from the host and if it fails but the pinging the IP succeeds then it is a DNS problem.
Alain
Ok how best do i resolve this issue ?
what do i need to configure on the Router ?
Can you ping the IP from your host but fail to ping the FQDN ?
Alain
Yes i can ping the IP.  But FQDN failed to Ping
Can you tell us which DNS servers your host is using ?
Alain
The DNS SERVER IS : 80.89.176.10 & 80.89.176.11
which is the DNS from the internet service provider.
In reading through this thread again I see that we talked about access list used for address translation but have not talked about the possibility of an access list applied to interfaces. So let me ask the question whether you have any access lists that are doing packet filtering on interfaces? If so please give us the details of this. I am wondering about the possibility that DNS traffic might be denied by access lists.
And if it is not an access list issue I wonder what else might be in the config that could impact DNS. So perhaps it would be helpful to post the complete config, masking out public addresses, passwords, and anything else that is sensitive.
Rick
Rick
