routes are not exchanging
Zulqadar Ahmad
I have two routers R1 and R2 configured for RIP but routes are not exchanging.Please find the confguration and show commands.
R1 Configuration
router rip
network 10.0.0.0
network 192.168.1
R2 Configuration
router rip
network 10.0.0.0
network 192.168.1
R1 show ip rip database
R1#sh ip rip database
10.0.0.0/8    auto-summary
10.15.1.0/24    directly connected, Loopback1
10.15.2.0/24    directly connected, Loopback2
10.15.3.0/24    directly connected, Loopback3
10.15.4.0/24    directly connected, Loopback4
10.15.5.0/24    directly connected, Loopback5
10.15.6.0/24    directly connected, Loopback6
10.15.7.0/24    directly connected, Loopback7
10.15.8.0/24    directly connected, Loopback8
10.15.9.0/24    directly connected, Loopback9
10.15.10.0/24    directly connected, Loopback10
10.15.11.0/24    directly connected, Loopback11
10.15.13.0/24    directly connected, Loopback13
10.15.14.0/24    directly connected, Loopback14
10.15.15.0/24    directly connected, Loopback12
10.15.16.0/24    directly connected, Loopback16
10.15.17.0/24    directly connected, Loopback17
10.15.18.0/24    directly connected, Loopback18
10.15.19.0/24    directly connected, Loopback19
10.15.20.0/24    directly connected, Loopback20
10.15.21.0/24    directly connected, Loopback21
10.15.22.0/24    directly connected, Loopback22
10.15.23.0/24    directly connected, Loopback23
192.168.1.0/24    auto-summary
192.168.1.0/24    directly connected, FastEthernet0/0
R2#sh ip rip database
10.12.1.0/24    directly connected, Loopback1
10.12.2.0/24    directly connected, Loopback2
10.12.3.0/24    directly connected, Loopback3
10.12.4.0/24    directly connected, Loopback4
10.12.5.0/24    directly connected, Loopback5
10.12.6.0/24    directly connected, Loopback6
10.12.7.0/24    directly connected, Loopback7
10.12.8.0/24    directly connected, Loopback8
10.12.9.0/24    directly connected, Loopback9
10.12.10.0/24    directly connected, Loopback10
10.12.11.0/24    directly connected, Loopback11
10.12.12.0/24    directly connected, Loopback12
10.12.13.0/24    directly connected, Loopback13
10.12.14.0/24    directly connected, Loopback14
10.12.15.0/24    directly connected, Loopback15
10.12.16.0/24    directly connected, Loopback16
10.12.17.0/24    directly connected, Loopback17
10.12.18.0/24    directly connected, Loopback18
10.12.19.0/24    directly connected, Loopback19
10.12.21.0/24    directly connected, Loopback21
10.12.22.0/24    directly connected, Loopback22
10.12.23.0/24    directly connected, Loopback23
R1#sh ip protocols
Routing Protocol is "rip"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Sending updates every 30 seconds, next due in 29 seconds
  Invalid after 180 seconds, hold down 180, flushed after 240
  Redistributing: rip
  Default version control: send version 1, receive any version
    Interface             Send  Recv  Triggered RIP  Key-chain
    FastEthernet0/0       1     1 2
    Loopback1             1     1 2
    Loopback2             1     1 2
    Loopback3             1     1 2
    Loopback4             1     1 2
    Loopback5             1     1 2
    Loopback6             1     1 2
    Loopback7             1     1 2
    Loopback8             1     1 2
    Loopback9             1     1 2
    Loopback10            1     1 2
    Loopback11            1     1 2
    Loopback12            1     1 2
    Loopback13            1     1 2
    Loopback14            1     1 2
    Loopback16            1     1 2
    Loopback17            1     1 2
    Loopback18            1     1 2
    Loopback19            1     1 2
    Loopback20            1     1 2
    Loopback21            1     1 2
    Loopback22            1     1 2
    Loopback23            1     1 2
    Loopback24            1     1 2
    Loopback25            1     1 2
    Loopback26            1     1 2
    Loopback27            1     1 2
    Loopback28            1     1 2
    Loopback29            1     1 2
    Loopback30            1     1 2
  Automatic network summarization is in effect
  Maximum path: 4
  Routing for Networks:
    10.0.0.0
    192.168.1.0
  Routing Information Sources:
    Gateway         Distance      Last Update
    192.168.1.1          120      00:00:03
  Distance: (default is 120)
R2#sh ip protocols
  Sending updates every 30 seconds, next due in 18 seconds
  Redistributing: rip
    Loopback1             1     1 2
    Loopback2             1     1 2
    Loopback3             1     1 2
    Loopback4             1     1 2
    Loopback5             1     1 2
    Loopback6             1     1 2
    Loopback7             1     1 2
    Loopback8             1     1 2
    Loopback9             1     1 2
    Loopback10            1     1 2
    Loopback11            1     1 2
    Loopback12            1     1 2
    Loopback13            1     1 2
    Loopback14            1     1 2
    Loopback15            1     1 2
    Loopback16            1     1 2
    Loopback17            1     1 2
    Loopback18            1     1 2
    Loopback19            1     1 2
    Loopback21            1     1 2
    Loopback22            1     1 2
    Loopback23            1     1 2
    Loopback24            1     1 2
    Loopback25            1     1 2
    Loopback26            1     1 2
    Loopback27            1     1 2
    Loopback28            1     1 2
    Loopback29            1     1 2
    Loopback30            1     1 2
  Maximum path: 4
    10.0.0.0
    192.168.1.0
    192.168.1.2          120      00:00:04
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 22 subnets
C       10.15.5.0 is directly connected, Loopback5
C       10.15.4.0 is directly connected, Loopback4
C       10.15.7.0 is directly connected, Loopback7
C       10.15.6.0 is directly connected, Loopback6
C       10.15.1.0 is directly connected, Loopback1
C       10.15.3.0 is directly connected, Loopback3
C       10.15.2.0 is directly connected, Loopback2
C       10.15.13.0 is directly connected, Loopback13
C       10.15.15.0 is directly connected, Loopback12
C       10.15.14.0 is directly connected, Loopback14
C       10.15.9.0 is directly connected, Loopback9
C       10.15.8.0 is directly connected, Loopback8
C       10.15.11.0 is directly connected, Loopback11
C       10.15.10.0 is directly connected, Loopback10
C       10.15.21.0 is directly connected, Loopback21
C       10.15.20.0 is directly connected, Loopback20
C       10.15.23.0 is directly connected, Loopback23
C       10.15.22.0 is directly connected, Loopback22
C       10.15.17.0 is directly connected, Loopback17
C       10.15.16.0 is directly connected, Loopback16
C       10.15.19.0 is directly connected, Loopback19
C       10.15.18.0 is directly connected, Loopback18
C    192.168.1.0/24 is directly connected, FastEthernet0/0
R1#
2#sh ip route
C       10.12.6.0 is directly connected, Loopback6
C       10.12.7.0 is directly connected, Loopback7
C       10.12.4.0 is directly connected, Loopback4
C       10.12.5.0 is directly connected, Loopback5
C       10.12.2.0 is directly connected, Loopback2
C       10.12.3.0 is directly connected, Loopback3
C       10.12.1.0 is directly connected, Loopback1
C       10.12.14.0 is directly connected, Loopback14
C       10.12.15.0 is directly connected, Loopback15
C       10.12.12.0 is directly connected, Loopback12
C       10.12.13.0 is directly connected, Loopback13
C       10.12.10.0 is directly connected, Loopback10
C       10.12.11.0 is directly connected, Loopback11
C       10.12.8.0 is directly connected, Loopback8
C       10.12.9.0 is directly connected, Loopback9
C       10.12.22.0 is directly connected, Loopback22
C       10.12.23.0 is directly connected, Loopback23
C       10.12.21.0 is directly connected, Loopback21
C       10.12.18.0 is directly connected, Loopback18
C       10.12.19.0 is directly connected, Loopback19
C       10.12.16.0 is directly connected, Loopback16
C       10.12.17.0 is directly connected, Loopback17
R2#
PLEASE CHECK WHAT COULD BE THE REASON THAT ROUTES ARE NOT EXCHANGING
THANKS
CCNA
CCNA :)
Hello.
I guess the issue is: you are using RIPv1 and auto-summary is in place.
cadet alain
hardcode RIPv2 and disable auto-summary and you'll see the loopbacks advertised by RIP on each router.
router rip
version 2
no auto-summary
Now for the explanation: each router is sending 10.0.0.0/8 network as the update is crossing a major network boundary and RIPv1 autosummarizes in this case.
When the other RIPv1 router receives this 10.0.0.0/8 it looks if it has already  network subnets part of this classful network known on other interfaces which is the case here and so it ignores  the update.
Alain
Hi Thanks for your reply.....
If i configure rip version 2 summarized address is recieved from both side and both network can ping each other.
But if i configured version 1 summraized address is not recieving i dont know what is the issue .
Whenever if i dont confgure no auto summary at version2 by default its Autosummary is on.(but still recieved summary address from both side)
and rip version 1 have only auto summary on.(but summmary address is not recieved)
CCNA :)
CCNA :)
I answered in my previous post:
This is how RIPv1 behaves, now in RIPv2 by default it also autosummarizes but it is now a classless protocol(not a classful one) and so it accepts the 10.0.0.0/8 network.
Alain
