Cisco 881 router needs to be restarted always
Rommel Pableo
I have a Cisco 881 router wherein everytime a hotel is getting no internet connection, they will just restart the router and all came back to normal. ISP is not an issue here since we are getting connectiong everytime we restart. I tried issuing show interface commands and I cannot see errors on the interface. I suspect this issue is due to high load utilization of the router that requires restarting to return to normal. Please give me some ideas on this.
show interfaces fastEthernet 2
FastEthernet2 is up, line protocol is up
Hardware is Fast Ethernet, address is d0d0.fde7.c70a (bia d0d0.fde7.c70a)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 5/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 185000 bits/sec, 172 packets/sec
5 minute output rate 2212000 bits/sec, 234 packets/sec
29612338 packets input, 3259648497 bytes, 0 no buffer
Received 19024 broadcasts, 0 runts, 0 giants, 0 throttles
38230113 packets output, 1942962425 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
show interfaces fastEthernet 4
FastEthernet4 is up, line protocol is up
Hardware is PQII_PRO_UEC, address is d0d0.fde7.c70c (bia d0d0.fde7.c70c)
Internet address is 42.61.215.115/22
reliability 255/255, txload 1/255, rxload 5/255
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
5 minute input rate 2167000 bits/sec, 225 packets/sec
5 minute output rate 171000 bits/sec, 164 packets/sec
38198543 packets input, 1797012792 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
6 input errors, 0 CRC, 0 frame, 0 overrun, 6 ignored
0 watchdog
29402479 packets output, 3061565945 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
17 Replies 17
i have some idea
1.check for the negotiation of the isp mux to router need to be hardcoded to full duplex because interface resets have happened
2.enable logging server which can provide it is free , we can analze
Rommel Pableo
hi guys,
just to update you on this. We ended up replacing the router since the customer had also upgraded their Internet speed to 100mbps. About 1-2 weeks already and we never faced any internet issue already.
many thanks for all your help.
Like I said, replace the router.
Thanks for the update.
