CISCO 881 ROUTER
AhmedQa
its my configuration right ? only need review and check if there is any mistake in my settings.
#show running-config
Building configuration...
Current configuration : 2013 bytes
ip domain name saudi.com.sa
ip name-server 84.235.6.xx
ip name-server 84.235.57.xxx
ip cef
no ipv6 cef
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
 ip virtual-reassembly in
 duplex auto
 speed auto
interface FastEthernet4.1115
 description " TO ITC Modem "
 encapsulation dot1Q 60
 ip address 37.224.119.xx 255.255.255.254
 ip nat outside
interface Vlan1
 description " Conneted To Switch "
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet4.1115 overload
ip route 0.0.0.0 0.0.0.0  0.0.0.0 0.0.0.0 37.224.119.xx
access-list 101 deny   ip any 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
you need to remove the 'deny' statement from your access list 101. You could also add DHCP server functionality to your router (this is of course optional):
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
ip nat outside
interface Vlan1
ip nat inside
no ip http server
--> no access-list 101 deny ip any 192.168.1.0 0.0.0.255
8 Replies 8
ip dhcp pool LAN
dns-server 8.8.8.8
ip cef
no ipv6 cef
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
ip nat outside
interface Vlan1
ip nat inside
no ip http server
once i start to configured the subinterface i got this message
subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q, or ISL vLAN
The "ip route" has an additional block of "0.0.0.0 0.0.0.0", the rest looks ok.
Hello
what is servicing your LAN for dynamic ip address allocation (dhcp)
Kind Regards
Paul
am using the static IP for my LAN network
AhmedQa
i found many issue when i start configuration the cisco router 881
first:
ip nat outside
the message appeared:
Warning: use /31 mask on non point-to-point interface cautiously.
--> Warning: use /31 mask on non point-to-point interface cautiously.
This is just the IOS telling you that you have to be sure that you use an IP address that has a corresponding peer address on the other side.
You can proceed with configuring that IP address on the interface, right ?
its already proceed with interface but the interface status is down.
Router#
Router#sh ip int br
Interface                  IP-Address      OK? Method Status                Prot                           ocol
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES NVRAM  administratively down down
FastEthernet4.1            37.224.119.XX   YES manual administratively down down
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      192.168.1.1     YES NVRAM  down                  down
Router#
