Cisco 881 setup
Good evening all,
I am presently working with an old Cisco 881 router. I have reset it to factory and begun the initial configuration. All interfaces are receiving/sending DHCP. However, I can not seem to get traffic out of the router. I have the default route set to FastEthernet4 where my internet connection is.
Guidance would be very helpful at this point.
5 Replies 5
here is a basic sample configuration. If you don't get it to work, post what you have so far, and we can fill in the necessary bits and pieces:
ip dhcp excluded-address 192.168.100.1
ip dhcp pool LAN
import all
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
dns-server 8.8.8.8 8.8.4.4
lease infinite
ip cef
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
ip tcp synwait-time 10
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN
ip address dhcp
ip nat outside
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex full
speed 100
interface Vlan1
description LAN
ip address 192.168.100.1 255.255.255.0
ip nat inside
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
access-list 1 permit 192.168.100.0 0.0.0.255
The original poster has not provided much detail for us to work with. So it is difficult for us to give good advice. The example provided by Georg is an excellent place to start. If that does not enable the original poster to solve the issue then the original poster needs to provide detail of how the 881 is configured. In my experience there are two issues that frequently are involved when the issue is described that traffic will not go from the router to outside. These are not correctly configured default route or not correctly configured NAT. So I suggest that the original poster pay particular attention to those parts of the config provided by Georg.
Rick
Rick
Once I figure out how to pull the configuration from the old winXP box connected to the router I will get it posted. For some reason I have been unable to connect to it with anything except that machine. I'm pretty sure the firmware needs an update pretty badly as well. I will review the setting provided and see where my configuration differs.
Here is my current config.
It looks like I need to get NAT configured and FE4 configured as outside. See anything else?
creston#show running-config
Building configuration...
Current configuration : 7351 bytes
! Last configuration change at 03:02:28 UTC Thu Jan 18 2018 by joe
version 15.0
no service pad
hostname creston
boot-start-marker
boot-end-marker
logging buffered 51200
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1590039077
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1590039077
 revocation-check none
 rsakeypair TP-self-signed-1590039077
crypto pki certificate chain TP-self-signed-1590039077
 certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31353930 30333930 3737301E 170D3137 31323238 31303434
  31305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35393030
  33393037 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  810093A1 561DD1D8 B2C8AC41 96BCBCC1 EF5621CE 9CDC97DB B543FE64 12FBD7A1
  20F9C7E4 6DA7E722 C58701AB C46C447C 97F3AEA7 146778C5 C75B2E1D 1B073030
  485FA3D6 F9864D82 EAE546D9 D6DC72BA CAE4A7E7 F1CF542C A3898653 00B0BEFE
  D01DFF60 1FAFE1CE E1D58DC7 3478FBC0 6A75DBF8 7DF700AD AA2B66B7 58C96640
  75470203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 14367CE7 6A5F2159 0B9EB04D DD225A21 087D1000
  E3301D06 03551D0E 04160414 367CE76A 5F21590B 9EB04DDD 225A2108 7D1000E3
  300D0609 2A864886 F70D0101 04050003 81810064 20EC7D6D A93C00DF 0632B720
  3F1E6432 E800668D 49CD6A2E AE1370E0 1AA6C553 91FD17F5 9A997B4B 6F29F23E
  0635BB2A C41B0CA8 71FDE7F0 B81BDA12 18179912 041DBD79 F40CCEE0 CDD26C1A
  60783F58 BB294C34 4F879B4E 7CAE5E39 DDF2420A BCC9CD76 E0E92CF6 61485609
  62D75FB8 CB682E99 96C0252A 73900009 6AC7F7
        quit
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.7 10.10.10.254
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   dns-server 75.75.75.75
   lease 0 2
ip dhcp pool ccp-pool1
   network 10.10.10.0 255.255.255.0
ip cef
ip domain name grhousing.org
ip name-server 75.75.75.75
ip name-server 75.75.76.76
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FTX1510031T
username joe privilege 15 secret 5 $1$/TtG$81p.1/60Y7tn74gR71p7T/
class-map type inspect match-any ccp-cls-insp-traffic
 match protocol cuseeme
 match protocol dns
 match protocol ftp
 match protocol h323
 match protocol https
 match protocol icmp
 match protocol imap
 match protocol pop3
 match protocol netshow
 match protocol shell
 match protocol realmedia
 match protocol rtsp
 match protocol smtp
 match protocol sql-net
 match protocol streamworks
 match protocol tftp
 match protocol vdolive
 match protocol tcp
 match protocol udp
class-map type inspect match-all ccp-insp-traffic
 match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-all ccp-invalid-src
 match access-group 100
class-map type inspect match-all ccp-icmp-access
 match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
 match protocol http
policy-map type inspect ccp-permit-icmpreply
 class type inspect ccp-icmp-access
  inspect
 class class-default
  pass
policy-map type inspect ccp-inspect
 class type inspect ccp-invalid-src
  drop log
 class type inspect ccp-protocol-http
  inspect
 class type inspect ccp-insp-traffic
  inspect
 class class-default
  drop
 class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
 service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
 service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
 description $ETH-WAN$$FW_OUTSIDE$$ES_WAN$
 ip address dhcp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 zone-member security out-zone
 duplex auto
 speed auto
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
 ip address 10.10.10.1 255.255.255.0
 zone-member security in-zone
ip http server
ip http access-class 23
ip route 0.0.0.0 0.0.0.0 Vlan1
logging trap debugging
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE
PUBLICLY-KNOWN CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL
NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
 login local
 no modem enable
line aux 0
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input telnet ssh
scheduler max-task-time 5000
end
I have simplified your configuration, the below should get you Internet connectivity. Once you have that, we can add (if necessary) the zone based firewall back:
Important/essential parts are marked in bold:
version 15.0
no service pad
hostname creston
boot-start-marker
boot-end-marker
no aaa new-model
quit
ip source-route
import all
dns-server 8.8.8.8 8.8.8.4
lease 0 2
ip cef
no ipv6 cef
ip address dhcp
ip nat outside
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface Vlan1
ip nat inside
ip http server
access-list 1 permit 10.10.10.0 0.0.0.255
access'list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
