Cisco 886VA, VDSL over ISDN with PPPoE
grodoni
I will install in the next days a 886VA router (VDSL over ISDN using PPoE).
Since I have no possibilty to verify the VDSL config, this is what i prepared.
Is this config Ok (only VDSL part) ?
controller vdsl 0
operating mode auto
interface Ethernet0
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname user_xxx
ppp chap password pwd_xxx
For VDSL over ISDN the interface Ethernet0 must be used instead of ATM .... Is this config correct ? Does anybody have an already working configuration ? thx.
6 Replies 6
grodoni
self-answer .... Config is Ok ! installed and works fine !
Please could you tell me the ISP that you have successfully connected your 886VA router to?
I have to set one of these up in Germany and connect it to "Deutsche Telekom T home" VDSL2 over ISDN Annex B.
The config' I have is like yours only with a "Interface vlan7" reference rather than the "Interface Ethernet0" that I don't understand the reason for!
Many thanks,
Vince.
Hi Vince,
I installed the router in CH (Swisscom VDSL).
I also have VLAN1 (you have vlan7) for the internal network.
But you need to configure ethernet0 the same as I did. Ethernet0 is a "virtual interface" to map the VDSL controller to the
dialer interface (in my case VDSL is mapped to dialer 1).
interface Ethernet0
Many thanks for your reponse.
I hope to give this a try soon, I will use your recommendation.
I have tried the VDSL config above for a T-Home VDSL Line. I can confirm it is not working if you have no tagged VLAN 7 on the ethernet 0 Interface.
Here a example that works for my T-home line.
interface Ethernet0
no ip address
interface Ethernet0.7
encapsulation dot1Q 7
interface Dialer1
ip mtu 1492
ip nat outside
ip virtual-reassembly in max-reassemblies 1024
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ANSCHLUSSKENNUNGT-ONLINENUMMER#0001@t-online.de password 0 PASSWORD
ppp ipcp dns request
ppp ipcp route default
Have fun with it
Best regards,
Mark
rolfwolff
could you post the complete config? We have a problem with an 886VA in Switzerland. We want to connect over VDSL and Dialer 1 to our VPN router here in Germany, but no connection could be established. We can't ping any public IP from the router. The VDSL was UP.
Any ideas?
Thank you.
Rolf
