Cisco 887 ADSL connection problem
Piotr Kowalczyk
I have problem with Cisco 887 and ADSL connection and wonder if somebody can advice something. It is new installed device and was working fine for last 2 weeks. Today got a call from the site about internet problem so tried to get access to router and wasn’t able. Asked them to reboot and it started to work – unfortunately wasn’t able to get access to the device when it was down.
Called ISP and was told, no problem on their site, they were able to see on their logs the device was down since 9pm yesterday. As I don’t have logging server not able to check this on our site.
Do you know about any setting which may affect the ADSL connection this way? Please find config below:
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip flow ingress
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ***********
ppp chap password 7 *****************
ppp pap sent-username *********** password 7 ************
no cdp enable
crypto map SDM_CMAP_1
3 Accepted Solutions
mavespig
Level 3
Level 3
Hello Piotr,
Perhaps the DSL line has a bad signal. Can you collect the output of show dsl interface atm 0?
You should mainly focus on noise margin and attenuation.
Noise Margin: the higher the better. Under 8db the line with flap or it won't train up at all. Good values are over 14 db.
Attenuation: the lower the better. Over 60 you will have signal problems, better stay under 40.
Hope this helps
Marco
DS stands for Down Stream and US stands for Up Stream.
ATU stands for ADSL Terminating Unit.  R stands for Remote and C stands for I-forgot-what-C-stands-for.
Attenuation doesn't look good.  You want a very low number.  The Noise Margin is OK.
7.0 dB in the noise margin is not a good thing.And by the values of your attenuation you are a little bit far from the CO.
You have to talk to your ISP.
5 Replies 5
mavespig
Level 3
Level 3
Hello Piotr,
Hope this helps
Marco
Marko,
Many thanks for your reply. Could you advise which value should I look at? ATU-R or ATU-C?
What is a difference between them?
Once again many thanks for your help.
                          ATU-R (DS)                      ATU-C (US)
Noise Margin:         21.5 dB                          7.0 dB
Attenuation:            23.0 dB                         10.5 dB
Marco, leolaohoo, David,
Many thanks for your profesional help. I will talk to ISP than.
