Cisco 887 ADSL setup - please help the stupid.
darren.g
Level 5
Level 5
Folks.
I'm going nucking futs trying to get this to work - I know it's something stupidly simple, and I know I should remember how to do this, but it's been 10 years since I set one of these up from scratch, and it's been a long week.
Work has an ADSL service - it's used for a backup in the event of a catostrophic failure of our normal infrastructure (in reality, it gets used for testing and not much else) which has been running on this crappy old billion router which fails about a dozen times a day.
I've got a bunch of 887's hanging around from another project, so I finally went "Stuff it, I'm putting in an 887".
I configured it, got it talking to ADSL, got it talking to the wireless point hanging off it, got the wireless working and getting IP allocation, I can telnet into the router and PING outside addresses - but I can't make NAT work for addresses on VLAN1.
I plead for assistence. I don't care if you laugh in my face and say "Darren, you idiot, you forgot <this miniscule command>" I just need to fix it and get on with other things which I'm currently stressing about (don't get me started on integrating Juniper and Cisco, or Microsoft bl***dy Lync, trust me).
Redacted/abbreviated config posted below - please, someone tell me what I've done wrong.
version 15.0
hostname router
no aaa new-model
memory-size iomem 10
clock timezone AEST 10
clock summer-time ADST recurring 1 Sun Oct 2:00 1 Sun Apr 3:00
ip source-route
ip dhcp pool 192.168.25.0/24
   network 192.168.25.0 255.255.255.0
   default-router 192.168.25.254
   dns-server 139.130.4.4 203.50.2.71
   lease 5
ip cef
ip name-server 139.130.4.4
ip name-server 203.50.2.71
no ipv6 cef
ip ssh version 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
ip virtual-reassembly
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description Local LAN
ip address 192.168.25.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1420
hold-queue 100 out
interface Dialer0
ip address negotiated
ip mtu 1462
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname <redacted>
ppp chap password <redacted>
ppp ipcp route default
ip forward-protocol nd
ip http server
ip http secure-server
ip nat source list 10 interface Dialer0 overload
access-list 10 permit 192.168.25.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 20 in
exec-timeout 0 0
login local
transport input telnet ssh
cadet alain
"ip nat source list 10 interface Dialer0 overload"  should be "ip nat inside source list 10 interface Dialer0 overload"
Alain
cadet alain
Alain
Thanka Alain - I *knew* it was something stupidly simple - I just couldn't see the forest for the trees!
