Cisco 887 No ATM Interface
benmaguire
Not sure if anyone else has seen this, but I've recently purchased a new Cisco 887W router to use the ADSLoverPOTS, but I don't have an ATM interface in the config? There is a physical interface labelled ADSLoPOTS.
Are the new 880 routers supposed to do this and if so, does anyone know how to configure the ATM settings?
Outputs are below...
esbrt01#show ip int brie
BRI0 unassigned YES NVRAM administratively down down
BRI0:1 unassigned YES unset administratively down down
BRI0:2 unassigned YES unset administratively down down
Dialer0 unassigned YES manual up up
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset down down
Vlan1 unassigned YES manual up up
Vlan80 10.148.80.1 YES NVRAM up up
Vlan81 10.170.128.1 YES NVRAM up up
Vlan82 10.148.82.1 YES NVRAM up up
Vlan102 10.148.102.1 YES NVRAM up up
Vlan113 10.148.113.1 YES NVRAM up up
Wlan-GigabitEthernet0 unassigned YES unset up up
wlan-ap0 10.148.80.1 YES TFTP up up
esbrt01#sh ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 12.4(20)T4, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Sep-09 06:51 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
esbrt01 uptime is 21 minutes
System image file is "flash:c880data-universalk9-mz.124-20.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If
Cisco
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 ISDN Basic Rate interface
1 terminal line
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Information for 'c880-dat...
6 Replies 6
887 should have atm interfaces. The output you see looks similar to what you would see on an 886. Make sure
there's not an 886 chipset inside an 887 chassis (highly unlikely). You might want to contact your reseller
Thanks Ronit
I'll go back to the reseller... must be a faulty unit :-(
What did you find out?   I think I have the same problem.
Everything is pretty much exactly the same as you listed, no ATM interface.
Hey
Yes, it was resolved by upgrading to IOS 15.0.1... must be a bug in the IOS it was shipped with.
Sorry, I did mean to post it on here but forgot... Let me know how you get on.
I have also seen this reported for the 867, apparently shipping with an IOS version that predated the first supported version for that platform!
http://www.dslreports.com/forum/r23756978-Config-Cisco-router-867-what-is-the-DSL-interface
jmvandam1988
As I can see in your post that you have the following ROM:
- System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
You are trying to run the following IOS:
- c880data-universalk9-mz.124-20.T4.bin
This IOS version is not downloadable on the "Download Software" section of the Cisco 887,not even in the archive. I recently ordered a Cisco 887, they currently default ship with the following IOS:
- c880data-universalk9-mz.124-22.YB2.bin
To solve the problem I would try to upgrade to the version they currently ship with, although it is a special train (YB) and not the technology train (T) it does work.
