Cisco 887 QOS on Ethernet WAN
Peter Sheridan
I've got a Cisco 887 (C887VA-W-A-K9) router connected to an Ethernet WAN service. I know 887s are typically meant for DSL connections, but the customer didn't want to spend money on a new router.
The ISP requires that traffic is shaped on the upload to match what they are paying for.
The customer is paying for a 40/40Mbps connection. The WAN comes in on port FastEthernet1. Config is below.
IOS Version: c800-universalk9-mz.SPA.151-4.M4.bin
policy-map SHAPE-WAN
class class-default
shape average 38000000
interface FastEthernet1
switchport access vlan 999
no ip address
duplex full
speed 100
service-policy output SHAPE-WAN
interface Vlan999
description WAN
ip address 111.111.111.111 255.255.255.252
ip nat outside
ip virtual-reassembly in
I'm finding that the policy map isn't actually doing anything. All of my research has lead me to believe that it is not possible on the type of router i'm using because it doesn't have any native Layer 3 ports.
Anyone got thoughts on how to make this work?
Peter
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Most 800 series Ethernet ports are just L2 port, unless the 8xx has a "WAN" Ethernet (routed) port.
Have you tried the shaping policy on the SVI?
HI Joseph,
Yeah I think that's the problem. Every time I try and apply the policy to the SVI it throws back the error "Configuration Failed".
Doesn't look like it's possible.
