Cisco 887VA ADSL cannot dialup connection
bishaal.bhusan
Could anyone please help me configure my new CISCO 887VA ADSL router.
I cannot get the dialer to establish a connection.
I have an ADSL2 connection from ISP with an LLC encapsulation and pvc of  0/35, below is my router config.
Router#sh run
Building configuration...
Current configuration : 2068 bytes
! Last configuration change at 21:17:24 UTC Mon Sep 3 2012
! NVRAM config last updated at 21:17:25 UTC Mon Sep 3 2012
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
shell processing full
no logging console
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp pool LAB-Pool
import all
network 192.168.0.0 255.255.255.0
dns-server 202.62.124.238 202.62.120.4
default-router 192.168.0.1
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FGL163224PV
controller VDSL 0
interface Ethernet0
no ip address
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/35
  encapsulation aal5snap
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description Internal LAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxx
ppp chap password 0 xxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxx password 0 xxxxxxxxxx
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
line con 0
line aux 0
line vty 0 4
login
transport input all
end
Router#
5 Replies 5
paolo bevilacqua
Start checking "show controller vdsl 0".
Then if it is RFC bridged connction, as opposed to PPPoE, your configuration is completely wrong. Otherwise is only partially wrong. Confirm with ISP, if you are not assigned username/password, it's bridged RFC.
I managed to fix the issue with help from ISP engineer, thanks Masi.
Changed the configs on the ATM0.1
     pvc 0/35
     pppoe-client dial-pool-number 1
Dialer could establish a connection to ISP after this.
Note that you need
on VLAN interface, not Dialer.
Hi Paolo,
I have actually tested this - and it turned out that the ip tcp adjust-mss applies to both ingress and egress traffic and can be safely placed on Dialer interface as well. That makes it actually even more simple to deploy if there are several internal interfaces, as placing this command on the Dialer interface will make it apply to all traffic exiting the router towards the DSL.
Best regards,
Peter
That makes sense. Good advice Peter.
