Bookmark
Subscribe
2535
Cisco 887VA and VDSL Vectoring Problem
GEORGE POLYZOS
Hello
I am novice to Cisco and I am asking for your help
I have a Cisco 887VA-K9
I configured in the past and since 2015 it operated flawlessly with VDSL 50mbits speed . Recently my ISP (Cosmote /Greece) has applied vectoring and since then the router only syncs with ADSL speed and not connecting
I don’t know if the problem is my firmware or anything else . Thank you Very Much
My Running Configuration is
Using 5976 out of 262136 bytes
! Last configuration change at 17:17:18 Athens Sun Dec 4 2016
! NVRAM config last updated at 17:17:40 Athens Sun Dec 4 2016
version 15.1
no service pad
hostname cisco887
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5
enable password
aaa new-model
aaa session-id common
memory-size iomem 10
clock timezone Athens 2 0
clock summer-time Athens date Mar 30 2003 3:00 Oct 26 2003 4:00
crypto pki trustpoint TP-self-signed-1627569428
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1627569428
revocation-check none
rsakeypair TP-self-signed-1627569428
crypto pki certificate chain TP-self-signed-1627569428
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
ip source-route
ip cef
ip domain name cisco887
ip name-server 195.170.0.1
ip name-server 195.170.2.2
ip port-map user-protocol--1 port tcp 26433
no ipv6 cef
license udi pid CISCO887VA-K9
username password
controller VDSL 0
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 101
match protocol user-protocol--1
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
inspect
class class-default
pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-user-protocol--1-1
inspect
class class-default
drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
drop log
class type inspect ccp-protocol-http
inspect
class type inspect ccp-insp-traffic
inspect
class type inspect ccp-sip-inspect
inspect
class type inspect ccp-h323-inspect
inspect
class type inspect ccp-h323annexe-inspect
inspect
class type inspect ccp-h225ras-inspect
inspect
class type inspect ccp-h323nxg-inspect
inspect
class type inspect ccp-skinny-inspect
inspect
class class-default
drop
class class-default
drop
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
interface Ethernet0
description COSMOTE2
ip address dhcp
interface Ethernet0.835
encapsulation dot1Q 835
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description $FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Dialer0
mtu 1492
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username password
ppp ipcp dns request
interface Dialer6
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 199 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 99 permit 10.10.10.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 10.10.10.3
access-list 199 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
dialer-list 3 protocol ip permit
dialer-list 4 protocol ip permit
dialer-list 5 protocol ip permit
dialer-list 6 protocol ip permit
dialer-list 7 protocol ip permit
! Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
cisco887 uptime is 2 days, 3 hours, 25 minutes
System returned to ROM by reload at 17:23:57 Athens Thu Feb 28 2019
System restarted at 17:24:46 Athens Thu Feb 28 2019
System image file is "flash:c880data-universalk9-mz.151-4.M5.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco 887VA (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Information for 'c880-data'
License Level: advsecurity Type: Permanent
Next reboot license Level: advsecurity
NAME: "887VA", DESCR: "887VA chassis, Hw Serial#: , Hw Revision: 1.0"
PID: CISCO887VA-K9 , VID: V02, SN:
Controller VDSL 0 is UP
Daemon Status: Up
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'BDCM'
Chip Vendor Specific: 0x0000 0xA4A1
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: 887VA-K9 15.1(4)M
Serial Number Far: eq nr port:12 oemid softwarerev
Modem Version Near: 15.1(4)M
Modem Version Far: 0xa4a1
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.992.5 (ADSL2+) Annex A
TC Mode: ATM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Trellis: ON ON
Line Attenuation: 1.0 dB 5.5 dB
Signal Attenuation: 1.0 dB 5.0 dB
Noise Margin: 9.1 dB 10.1 dB
Attainable Rate: 19276 kbits/s 1180 kbits/s
Actual Power: 0.7 dBm 12.1 dBm
Total FECS: 11684 0
Total ES: 163 0
Total SES: 1 0
Total LOSS: 0 0
Total UAS: 0 0
Total LPRS: 0 0
Total LOFS: 0 0
Total LOLS: 0 0
Bit swap: 306 0
Full inits: 10
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Firmware Source File Name (version)
VDSL embedded VDSL_LINUX_DEV_01212008 (1)
Modem FW Version: 110506_1916-4.02L.03.A2pv6C032b.d23i
Modem PHY Version: A2pv6C032b.d23i
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 18143 0 1165
Previous Speed: 0 17749 0 1154
Total Cells: 0 766795386 0 49259381
User Cells: 0 3387 0 0
Reed-Solomon EC: 0 11684 0 0
CRC Errors: 0 290 0 0
Header Errors: 0 3328 0 0
Interleave (ms): 0.00 6.98 0.00 9.58
Actual INP: 0.00 0.33 0.00 0.83
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
I have made some changes/additions (marked in bold) to your configuration, check if you get it to work:
version 15.1
no service pad
hostname cisco887
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5
enable password
aaa new-model
ip source-route
ip cef
no ipv6 cef
username password
controller VDSL 0
--> operating mode vdsl2
or
--> operating mode auto
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol h323
match protocol sip
match protocol http
inspect
class class-default
pass
inspect
class class-default
drop
drop log
inspect
inspect
inspect
inspect
inspect
inspect
inspect
inspect
class class-default
drop
class class-default
drop
interface Ethernet0
--> no ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
--> no ip mtu 1452
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip http server
ip nat inside source list 1 interface Dialer0 overload
--> no ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 10.10.10.0 0.0.0.255
Hello
I made the changes/additions you advise me but unfortunately it did not work . It Syncs on ADSL Speed  and is not connecting . When I change to operating mode vdsl2 it does not sync at all
The problem is that I don’t have a Cisco Service Contract so I cannot upgrade my IOS and Firmware
Thank you for the help you gave me
My Configuration :
Building configuration...
Current configuration : 7296 bytes
! Last configuration change at 22:29:06 Athens Wed Mar 6 2019
version 15.1
no service pad
hostname cisco887
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5
enable password
aaa new-model
ip source-route
ip cef
no ipv6 cef
username password
controller VDSL 0
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol h323
match protocol sip
match protocol http
inspect
class class-default
pass
inspect
class class-default
drop
drop log
inspect
inspect
inspect
inspect
inspect
inspect
inspect
inspect
class class-default
drop
class class-default
drop
interface Ethernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
interface Dialer6
no ip address
shutdown
ip http server
line con 0
no modem enable
line aux 0
line vty 0 1
password t
transport input ssh
line vty 2 4
password
transport input none
end
amikat
To support VDSL vectoring (ITU-T G.993.5) your VDSL (modem) firmware needs to be at least 38h, ie. you need upgrade.
Best regards,
Antonin
