Cisco 887VA PPPoA BT ADSL setup?
almailing
Sorry to bother you all.
Im new to Cisco equipment and weve just upgraded to a all singing 8000 series (887VA) to be precise.
i'm having difficultys in setting the router to connect to our BT ADSL2 business broadband, we have a static IP but on normal cheaper routers you just input a Chap username and password. and the router sorts the rest.
i've followed the tech support from cisco website inputted the configure commands to create the ATM0 and a Dialer0 but still having no joy.
this is the link to what i followed http://bit.ly/xLN3iB
when you log into the gui it only shows you a enable PPPoE tick box. no signs of PPPoA?
i can supply config file if you can help?
Kevin
21 Replies 21
ammahend
Ensure that the RJ11 cale is connected to the atm interface on the router
information below mentioned in italic has to be either given by ISP or you can configure your own self
Router>en
Router#conf t
Router(config)#interface Vlan1
Router(config-if)#description internal interface
Router(config-if)#ip address 192.168.0.1 255.255.255.0
Router(config-if)#ip nat inside
Router(config-if)#no shut
OR (if you are using configurable internal Ethernet interface)
Router(config)#interface FastEthernet 0/1
Router(config)#interface ATM0
Router(config-if)#no ip address
Router(config-if)#no atm ilmi-keepalive
Router(config-if)#dsl operating-mode auto ( check the mode with isp )
Router(config)#interface ATM0.1 point-to-point
Router(config-subif)#pvc 0/35(Either 0/35 or 8/35 depending upon the ISP)
Router(config-if-atm-vc)#pppoe-client dial-pool-number 1
( this is for binding ATM interface with a particular dialer interface )
Router(config)#interface dialer 0
Router(config-if)#ip address negotiated  (you need to know the ip is static is via dhcp from isp)
Router(config-if)#ip mtu 1492
Router(config-if)#ip nat outside
Router(config-if)#encapsulation ppp
Router(config-if)#dialer pool 1
Router(config-if)#ppp authentication chap pap callin ( Multiple options are there..we can choose auth method according to the situation )
Router(config-if)ppp pap sent-username USERNAME password P@ssw0rd (ISP given)
Router(config-if)#ppp chap hostname HOSTNAME (Username given by ISP)
Router(config-if)ppp chap password P@ssw0rd(password given by ISP)
Router(config)#access-list 101 permit ip 192.168.0.0 0.0.255.255 any
Router(config)#ip nat inside source list 101 interface dialer 0 overload
Router(config)#ip dhcp pool sdm-pool
Router(dhcp-config)#network 192.168.0.0 255.255.255.0
Router(dhcp-config)#dns-server Primary DNS IP address Secondary DNS IP address (obtained from your ISP)
Router(dhcp-config)#default-router 192.168.0.1 (internal VLAN or Ethernet interface Ip address)
Router(dhcp-config)#import all
Router(config)#ip route 0.0.0.0 0.0.0.0 dialer 0
Thank you
Ambuj
**Rate this doc if you find it helpful and help the community**
-hope this helps-
ammahend
Also ensure that the BT device is set to bridge mode as the cisco router will do the layer 3 functionality and BT router will only act as a bridge to connect cisco router to the ISP.
-hope this helps-
well i tried that and have more lights on the cisco. PPP light etc. but no internet.
"Also ensure that the BT device is set to bridge mode as the cisco router will do the layer 3 functionality and BT router will only act as a bridge to connect cisco router to the ISP."
i thought this router has a modem in it so i didnt need a BT modem????
Config file bellow......
Building configuration...
Current configuration : 6979 bytes
! Last configuration change at 11:32:16 PCTime Mon Mar 5 2012 by admin
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname cisco887va
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
enable secret 5 $1$9rXK$owX21yb5tqUbxBcGWqQal.
no aaa new-model
clock timezone PCTime 0 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-281403735
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-281403735
revocation-check none
rsakeypair TP-self-signed-281403735
crypto pki certificate chain TP-self-signed-281403735
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32383134 30333733 35301E17 0D313230 32323331 35313532
  345A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3238 31343033
  37333530 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  E466BC6A 54918147 BDE8C2D5 6A76BC80 A1345602 F2BA37CD 566DC853 29B706D2
  C7F8C29D AEE97447 24D29ADE 8B13E148 92DB224B C6B44C04 D43F4451 F307574F
  E3A91DAF DF190622 F83C5338 C8EF7BC3 075D702B CCC9FE15 F8B747B7 6FDB42D5
  66DE2833 27E01B04 DBC10F04 37B42916 956E8E71 3CEE9F42 AD07929E 7FB2796D
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014E1 6D333CE0 FCA77CA0 A1998D9C E08C8D94 7C8D8230 1D060355
  1D0E0416 0414E16D 333CE0FC A77CA0A1 998D9CE0 8C8D947C 8D82300D 06092A86
  4886F70D 01010505 00038181 008F31D1 8E5368E7 1838D3CC 111751E1 587B17A1
  24112A77 D90B7A70 30178A2E 6D65AA93 76FAAA41 83827500 72C69878 B9BDBB44
  3C62FCE9 51B3319D 0F3989C2 BBA2DEFB 40F00FE7 6DAE1A1D 65547428 DC7DD75B
  4A41BFB4 D85626C2 130424DD AD834673 E92E5FEE 737A89CC 50D5E5CC 927AAEDB
  18143149 E38E2E7C 6DB15EC1 01
            quit
no ip source-route
ip cef
ip dhcp excluded-address 192.168.222.1 192.168.222.200
ip dhcp excluded-address 192.168.222.4
ip dhcp pool ccp-pool1
import all
network 192.168.222.0 255.255.255.0
dns-server 208.67.222.222 208.67.220.220
default-router 192.168.222.4
ip dhcp pool almailing
import all
no ip bootp server
ip domain name al-mailing.co.uk (not sure)
ip name-server 208.67.222.222
ip name-server 208.67.220.220
no ipv6 cef
license udi pid C887VA-W-E-K9 sn FCZ1606C0A1
username admin privilege 15 secret 5 $1$MrNS$1xkjb5XPv.lelb/EG00HK1
controller VDSL 0
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0
description $FW_OUTSIDE$$ES_WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip virtual-reassembly in
pppoe-client dial-pool-number 2
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.222.4 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip tcp adjust-mss 1412
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname "ISP USERNAME"
ppp chap password 7 0305570607062D45400E48
ppp pap sent-username "ISP USERNAME password 7 094D4204180C1B1B050B55
no cdp enable
interface Dialer1
no ip address
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap password 7 0607032C4D4705100B1043
ppp pap sent-username "ISP USERNAME" password 7 0305570607062D45400E48
no cdp enable
interface Dialer2
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 1
ppp authentication chap callin
ppp chap password 7 020708560A0F0328424958
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer1
logging trap debugging
access-list 1 permit 192.168.222.4
access-list 101 permit ip 0.0.0.0 255.255.255.0 any
dialer-list 1 protocol ip permit
no cdp run
banner exec ^CCCC
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^CCCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
scheduler interval 500
end
You have entered a PPPoA configuration. I'm not aware of BT using PPPoA
Search for PPPoE configuration, and change to it.
Otherwise, take "show dsl interface",
The only information BT will provide me as Cisco is a third party router is my settings should be:
1. ATM Encapsulation PPPoA/VCMUX
2. Modulation-G.DMT
3. VPI-0
4. VCI-38
5. Authentication Method-CHAP
Kevin
Please take "show dsl interface" and "debug ppp negotiation" "debug ppp authentication" with "term mon". For these, reset the line, eg shut/no shut atm interfacce.
1.remove the atm interface config first
en
conf t
default int atm0
2.paste the config below.
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
  pvc 0/38
3.check if the dialer has Ip , if it has ip ping 4.2.2.2 from the router .
4.if dialer do not have ip , do debug ppp negotiaion and see if it is receiving confack (I) alsong with sending confreq (O)
If it doesnt work , call cisco Tac and open up a case , it should be 10 minutes job , once we have webex to your router.
-hope this helps-
HochtiefPhil
Hi Kevin Rock
I was wondering if you managed to get your Cisco router working with your BT connection as I have similar issues that you experienced up to your original post.  I'm fairly new to the configuration of the Cisco routers especially the Cisco 887VA but thanks to your posts I have been able to get the device connected with our BT ADSL2+ connection but we are not able to browse external websites.  We have contacted BT who have verified the device is connected and synchronised on their network and they are unsure as to why we are experiencing issues.  BT have provided us with 194.72.9.34 and 194.72.9.38 as the DNS server addresses for our connection but we are still unable to access sites.
Does anyone know from the configuration below why we would be experiencing these issues?
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1532457153
subject-name cn=IOS-Self-Signed-Certificate-1532457153
rsakeypair TP-self-signed-1532457153
crypto pki certificate chain TP-self-signed-1532457153
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31353332 34353731 3533301E 170D3132 30363138 31343232
  35335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35333234
  35373135 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009858 4796F26F 5F75079F DDDE1798 72B9DB04 C6F43166 423539AC F1F7F9A8
  A2197CD8 EE8296CF AA92F33C BB8B35B8 BF4F95B7 78631694 5F159102 46D98254
  78EF9FD3 CE922C81 DD91F9B6 079BFEE0 811E27E6 47136C85 C7B4F60C 41F3E225
  7E3A36E3 5C368194 C369A713 622E972E 52E657F0 6294F0E6 6B6A270F 0F45B936
  9A8B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 142B01F3 5D46E646 A116F705 CA54ACBA 5D511086 42301D06
  03551D0E 04160414 2B01F35D 46E646A1 16F705CA 54ACBA5D 51108642 300D0609
  2A864886 F70D0101 05050003 81810045 42DB1E4A 1F315511 6FD01294 1FD85143
  FC2BBE42 F12994FF 8F382B39 1C766261 D147902D DE14346A 73735870 7A0038C9
  7782F54C 70C063A7 7460F71D 4C0DAAF2 1C37F9A8 203E1558 D9D79593 72BE1656
  CB08DD09 8068869A 4D704596 6CE48B7F D48C5D10 E756D149 42F8BC4E 59DFB04B
  2EEBFE3B 0B87723D 7AFC36E9 D268C2
                quit
ip dhcp excluded-address 192.168.2.1
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip name-server 194.72.9.34
ip name-server 194.72.9.38
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ161993JL
username ************* privilege 15 secret 5 **************
controller VDSL 0
operating mode adsl2+
no ip ftp passive
interface Ethernet0
no ip address
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 0/38
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname ***********@hg7.btclick.com
ppp chap password 0 ***********
ppp pap sent-username **********@ht7.btclick.com password 0 *********
no cdp enable
interface Dialer1
no ip address
ip nat outside
ip virtual reassembly in
encapsulation ppp
dialer pool 1
ppp chap hostname **********@hg7.btclick.com
no cdp enable
interface Dialer2
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 1
ppp chap hostname *******@hg7.btclick.com
no cdp enable
ip http server
access-list 1 permit any
access-list 2 remark INSIDE_IF=Vlan1
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 192.168.2.0 0.0.0.255
no cdp run!
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
Remove all dialer interfaces except one, remove one NAT access-list, change NAT ACL to list your internal network, try again.
Thanks for the suggestion Paolo.  I've found the adsl connection won't work if I don't have the three dialers configured as verified by BT.  I had a feeling the issue was with the NAT configuration but wanted to have it clarified first.
No, that's impossible. Only one dialer is needed and used, the others that are not referenced under pvc 0/38 have no effect whatsoever. However it's good practice to keep configuration clean of unnecessary stuff.
Richard Swain
I'm just setting about configuring my first 887VA, I have been trying to follow the guide's here but there doesn't appear to be a single clean working config to work from.
I've noticed that my router doesn't accept the command dsl operating-mode auto so I've struggled to just get a config up and running on the device.
I was wondering if there was a basic guide to configuring this device on a BT ADSL circuit with DHCP as I think once I cover those basics I can probably work the rest out.
1. VA router do not have dsl-operting mode command. The qequivalente command goes under controller vdsl 0
2. BT ADSL normally uses PPPoE, not RFC/brdige and DHCP.
3. You can use the configuration example above, that include for points 1. and 2.
Hi Kevin/Ambuj:
I just purchase this router for an ADSL connection with BT, can you please confirm if this finally did work.
Ps: I am also buying it with the wireless addition
Cisco 887VA VDSL2/ADSL2+ over POTS W/802.11n ETSI Comp
If anyone of you configure teh 802.11n in this module this will be really preciatted as well.
Kind Regards, Alejandro.
