Cisco 887VA router and configuring with VDSL
timrichards1
Hey all, hoping you can help as I am pretty new to router config.
Ok, so last week switched one of our sub offices from adsl to vdsl and swapped out the old 887 router (which establishes a vpn connection back to head office) with a new one and the engineer who turned up said there would need to be some config change. We have tried but been unsuccessful so far so any help would be VERY much appreciated.
The original config on the router at the time of the change was:
! Last configuration change at 14:16:27 NZST Fri Jun 19 2015 by admin
! NVRAM config last updated at 09:33:38 NZST Fri Jun 19 2015 by admin
version 15.3
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname qtht_router
boot-start-marker
boot-end-marker
logging buffered 16000
logging console warnings
enable secret 5 $1$1mYn$g6TKB5R6it2MEeAu1JauP0
no aaa new-model
memory-size iomem 10
clock timezone NZST 12 0
clock summer-time NZDT recurring last Sun Sep 2:00 1 Sun Apr 3:00
crypto pki trustpoint TP-self-signed-3647631588
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3647631588
 revocation-check none
 rsakeypair TP-self-signed-3647631588
crypto pki certificate chain TP-self-signed-3647631588
 certificate self-signed 01
blah blah blah
   quit
no ip dhcp use vrf connected
ip dhcp excluded-address 10.200.41.1 10.200.41.99
ip dhcp excluded-address 10.200.41.200 10.200.41.255
ip dhcp pool HT_QT
 import all
 network 10.200.41.0 255.255.255.0
 default-router 10.200.41.254
 dns-server 192.168.2.13 10.0.10.9
 domain-name blah blah blah
no ip bootp server
ip inspect name firewall tcp
ip inspect name firewall ftp
ip inspect name firewall https
ip inspect name firewall sip
ip inspect name firewall pop3
ip inspect name firewall udp
ip inspect name firewall h323
ip inspect name firewall rcmd
ip inspect name firewall realaudio
ip inspect name firewall streamworks
ip inspect name firewall vdolive
ip inspect name firewall sqlnet
ip inspect name firewall tftp
ip inspect name firewall icmp
ip inspect name firewall fragment maximum 256 timeout 1
ip inspect name firewall netshow
ip inspect name firewall rtsp
ip inspect name firewall skinny
ip cef
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn FGL1715245G
archive
 log config
  hidekeys
username admin privilege 15 password 0 blah
controller VDSL 0
ip tftp source-interface Vlan1
ip ssh version 1
crypto isakmp key blah hostname blah blah blah
crypto ipsec client ezvpn EZVPN_QLDC
 connect auto
 group ezvpn_ht_qt key blah
 mode network-extension
 peer vpn.qldc.govt.nz
 peer 210.55.20.210
 username ezvpn_ht_qt password blah
 xauth userid mode local
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 description WAN_FW_OUTSIDE
 pvc 0/100
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
 switchport access vlan 202
 switchport mode trunk
 switchport voice vlan 202
 bandwidth 500000
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Virtual-Template1 type tunnel
 no ip address
 tunnel mode ipsec ipv4
interface Vlan1
 description Customer LAN
 ip address 10.200.41.254 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 ip inspect firewall in
 ip virtual-reassembly in
 crypto ipsec client ezvpn EZVPN_QLDC inside
interface Dialer0
 ip address negotiated
 ip access-group 101 in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip inspect firewall out
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp pap sent-username user@xtrabb.co.nz password 0 xtrabb07
 ppp ipcp dns request
 ppp ipcp route default
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 50
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 105 interface Dialer0 overload
ip nat inside source static tcp 10.200.41.1 3389 interface Dialer0 3389
ip access-list extended SIP
dialer-list 1 protocol ip permit
snmp-server community qldcpub RO
snmp-server location Housing Trust
snmp-server contact System Administrator
access-list 50 remark Gen-I Dean Shaw home
access-list 50 permit 219.89.206.32
access-list 50 remark Access from QLDC External IP
access-list 50 permit 210.55.20.208 0.0.0.7
access-list 50 permit 125.236.56.40 0.0.0.7
access-list 50 permit 122.56.13.176 0.0.0.15
access-list 50 remark Access from Internal IPs
access-list 50 permit 10.0.0.0 0.255.255.255
access-list 50 permit 192.168.0.0 0.0.255.255
access-list 101 remark Traffic allowed to enter the router from the Internet
access-list 101 remark DNS traffic
access-list 101 permit udp any eq domain any
access-list 101 remark NTP traffic
access-list 101 permit udp any any eq ntp
access-list 101 remark Crypto Traffic
access-list 101 permit udp any any eq non500-isakmp
access-list 101 permit udp any any eq isakmp
access-list 101 permit esp any any
access-list 101 remark Access from QLDC
access-list 101 permit ip 210.55.20.208 0.0.0.7 any
access-list 101 permit ip 125.236.56.40 0.0.0.7 any
access-list 101 permit ip 122.56.13.176 0.0.0.15 any
access-list 101 remark Spark Digital
access-list 101 permit ip host 219.88.71.1 any
access-list 101 permit ip 146.171.254.0 0.0.0.255 any
access-list 101 remark Other statements
access-list 101 deny   ip 0.0.0.0 0.255.255.255 any
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip 169.254.0.0 0.0.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 192.0.2.0 0.0.0.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 198.18.0.0 0.1.255.255 any
access-list 101 deny   ip 224.0.0.0 0.15.255.255 any
access-list 101 deny   ip any host 255.255.255.255
access-list 101 deny   ip any any log
access-list 105 remark Traffic to NAT
access-list 105 permit ip 10.200.41.0 0.0.0.255 any
access-list 190 permit udp any any eq domain
access-list 199 permit ip any any
control-plane
banner login CCCCCCCCCAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!
line con 0
 logging synchronous
 login local
 no modem enable
 transport output telnet
 speed 115200
line aux 0
line vty 0 4
 login local
 transport input telnet ssh
scheduler max-task-time 5000
ntp server 192.5.41.41 prefer source Dialer0
end
any suggestions would be REALLY welcome
5 Replies 5
basically, you need to make just a few adjustments:
controller VDSL 0
 operating mode adsl2+
Also, the pvc pair might have to be changed on your ATM point to point subinterface. If  'pvc 0/100' doesn't work, try and change it to 'pvc 0/38'.
What country are you in ? I am just asking because a few settings could be country specific.
Hi Georg
Many thanks for your reply, I am in NZ. Managed to get it sorted with the help of a Spark engineer, thanks again
Hello Tim
just out of curiosity, what changes did you make ? PVC 0/100 by the way is the right one for New Zealand...
No, it was a case of shutting down the ATM dialer and setting up the internal Ethernet0 interface
Hello Tim
Could you please post your running config.
Avi
