CISCO 888G crypto isakmp is not available
arnaldorafaelg
hi guys thanks for time and help i have issue the Crypto Isakmo is not working for me
i have the advsecurity licencesing enable for my 88G
what i have to check???
route(config)#crypto ?
  key               Long term key operations
  pki                 Public Key components
  provisioning  Secure Device Provisioning
  wui                 Crypto HTTP configuration interfaces
Device#   PID                   SN
*0        CISCO888G-K9          FGL154820YQ
License Information for 'c880-data'
    License Level: advsecurity_npe   Type: Permanent
    Next reboot license Level: advsecurity_npe
c880data-universalk9_npe-mz.152-1.T1.bin
thanks guys
janickle
Hi Arnaldo,
This may be an issue with the IOS version that you are running on the device.  While you may have the license needed for the security features your IOS may not support it.  It looks like the version you are running c880data-universalk9_npe-mz.152-1.T1.bin  is the non payload encryption version.  This is indicated by the npe in the name.
Jason Nickle
